Old 01-19-2004, 09:14 AM
carnutcass's Avatar
carnutcass carnutcass is offline
Wing Removal
St. Louis GP Club had a Mod Day yesterday and I did something I'd been procrastinating about. If you haven't done this yet I would recommend doing it as soon as you can.
Our wings are mounted tightly against the deck lid by 6 studs w/nuts. There's also some adhesive used but it's minimal. I removed my wing for the purpose of inserting "spacers" between the wing and deck lid so that water can drain. When I removed my wing I was amazed at the amount of shit trapped beneath it. There was pine needles, dirt, small rocks, and grime under there......and I wash my car very often! I was also a little aggravated by the amount of pitting there was in my paint. The car is an '02 for god's sake!
Anyway, I cleaned eveything up and installed 5/16" rubber grommets in the holes in the deck lid. I reinstalled the wing and tested for effectiveness with warm water (It was below freezing here). Success. Also looked insinde the trunk for leakage and there was none.
I'd recommend to everyone that they do this. I wish I hadn't waited so long. DOH!!!! I'd bet some of the cars are rusting under there.
Old 01-19-2004, 03:53 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
I was attempting this same mod at lunch today but forgot my tools (torque bits)
Never thought about using gromets I did find some rubber washer that are used for water hoses that Im going to use.
I can wash the car on a monday and on a thursday I open the trunk and water still comes down the lid.
Old 01-19-2004, 04:54 PM
carnutcass's Avatar
I talked to a couple of guys in the group and they complained that the hose washers had a tendancy to stick out from beneath the wing when tightened down. The grommets are also nice because they stay in place while you reposition the wing for installation. They're cheap and they're available everywhere: Home Depot, Lowes, Sears Hardware, etc.
Three of the six holes are elongated so the grommets conform nicely to the oval shape.
Old 01-19-2004, 05:19 PM
Ripn12s's Avatar
Cool
Just got done. Deck lid wasnt too bad for being a 98.
Clay'd the lid and applied some wax. Im going out alittle later to test for leaks. It's going to be so nice to not have water get stuck under the wing.
Old 01-21-2004, 11:01 AM
wbs97gp wbs97gp is offline
Wink Soiler gromets
I just purchased a set of seals from the local Pontiac dealer.
The part # is 20733729, and they are about 3/4" diameter, and about 1/8 inch thick.
I too have noticed that water stays under the spoiler for a long period of time.
I'll see how these work, and if they don't, I will try a different route.
Thanks
Walter
Old 01-21-2004, 11:35 AM
DarkTint DarkTint is offline
Send a message via Yahoo to DarkTint
"St. Louis GP Club had a Mod Day yesterday and I did something I'd been procrastinating about."
Can you post a link to the St. Louis GP Club? I live in St. Louis and would be interested to see it.
DarkTint
1999 Grand Prix GT 2-Door
2008 Honda CBR600RR
Old 01-21-2004, 11:52 AM
carnutcass's Avatar
www.stlclubgp.com
It's a great group.......95 members, 30 of which are regulars at gatherings. Gatherings range from Mod Days, to evenings at the track, to dinner at a restaurant. We get together at least once a month. There's no membership fee and no requirement as far as whether or not you come to gatherings. Hope to see you there. My name is Cassidy on the message board.
Old 01-21-2004, 04:07 PM
Thanks for the info. I checked it out, and am now the newest member.
DarkTint
2008 Honda CBR600RR
Old 01-25-2004, 10:22 AM
2000GrandPrixGT 2000GrandPrixGT is offline
Re: Soiler gromets
I'm going to take my spoiler off today, and see what is hiding under there. If those seals work, I'll definitely install them.
How did they work on your Pontiac? Thanks for the help.
Old 01-25-2004, 10:46 AM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Re: Wing Removal
Well when I installed the SLP one a lot of crap came out of it. Never tought about raising it tought. I did polished the surface and re installed it. I need to seal it. If I wash the car with strong water stream water will leak in. I think raising my SLP wing would not look that good, will try the sealing and if it does not work then raising it a little
Old 01-26-2004, 12:08 PM
carnutcass's Avatar
We've had two days of freezing rain, sleet, and snow. No leaks! I checked the trunk this morning when I got to work and it's dry.
Old 01-26-2004, 03:49 PM
Ripn12s's Avatar
I took the spoiler off, clayed the lid and applied a coat of polish. Rained the other day and the next morning I opened the trunk and water still came running down the damn lid. No leaks though. I think Im going to try and raise the spoiler by one more set of washers.
Old 01-29-2004, 02:28 PM
I removed the 6 studs under the deck lid, but the spoiler was still very snug. Is that the adhesive? And if so, how do you get the spoiler off with this adhesive on there?
Old 01-29-2004, 08:37 PM
Exclamation
The wing has some padds around the edges, that help keeping it from chafing the trunk lid, but what happens is that they stick.
It will take some working to get it off, but start from one end, and work it up all the way around.
I ordered the seals from Pontiac, you need 6, but they come in a pack of 10, @$1.70 ea. ($17 for the pack).
I found that I had a real mess under my spoiler (wing). Here in Florida we have a lot of flying sand, and it acted like sandpaper under the wing, so I had to grind and paint before putting it back toghether.
When I put it toghedter, I installed the seals between the wing and the trunk lid, dealer drawing shows them installed from inside the trunk, I also installed some shims between the wing and the trunk, to try to keep a gap so that thing will not collect between them anymore.
The shims that I installed came from a shim kit that is used to install a bed cover for the back of a pick-up truck, made by Edwards, they have adhesive on 1 side, and are made of a hard plastic, I put the adhesive side on the metal, so that it will not move around and chafe the trunk lid.
Good luck
Walter
Old 01-30-2004, 02:53 PM
carnutcass's Avatar
Re: Wing Removal
I've spoken with several people who have removed their wing. It's amazing to me that it seems GM tried something different every model year relative to the wing installation. Maybe they were trying to remedy all the leaking trunks out there.
Mine is an '02 and it had the rubber pads at the ends that Walter mentioned...... but I also had three spots of clear non-hardening adhesive: One in the center toward the rear and two about 6-8" off center toward the rear. There's a couple of things you can do to loosen the adhesive up.
Use a hair dryer or heat gun on low. Take your time! The adhesive will soften up fairly quickly with heat applied. Your other option is to go buy some adhesive remover from a parts store. Be really careful to get one that states that it won't hurt automotive finishes.
'00 COUGAR removing dash gw84 Cougar 0 04-28-2009 08:08 AM
1994 b-3000 radio removal zoobag General Discussion 1 04-05-2009 05:22 PM
91 wing removal? vr4choke 3000GT/Stealth 11 03-30-2009 07:34 PM
How To: Remove Door Panel LifeIsPain Montana/Montana SV6 1 03-21-2009 07:08 PM
Stock Rear Wing Removal red_line Off-Topic 10 10-10-2004 11:47 PM
