Old 01-19-2004, 12:17 AM
Rod123 Rod123 is offline
Rear end noise
Have noise in rear end loudest under load diminishes when letting off accelerator nearly non existent when shiffted into neutral. Blazer is '95 with 125,000 mi. What bearing is likely culprit and what is likely cost. I suspect I'm not first with this problem. Thanks
Old 01-19-2004, 09:41 AM
comp comp is offline
check and/or change diff gear lube first
Old 01-19-2004, 10:37 PM
Re: Rear end noise
Gear lube previosly changed and is full with correct type.
