Old 01-18-2004, 09:48 PM
GSX88 GSX88 is offline
Tuning when adding power upgrades?
when adding power to a 4g63 (100hp give or take) by uprgading turbo, exhaust etc, what kind of tuning will i need to do and how can i do this. If i would have it profesionaly tuned how much would i typicaly be charged? thanks
Old 01-19-2004, 02:04 AM
89Turbo944's Avatar
89Turbo944 89Turbo944 is offline
Re: Tuning when adding power upgrades?
Well it sounds like it would be a good idea to get it tuned by a professional.
First off you will need more than just a turbo and exhaust to make this all work. A boost guage would be a good idea, as well as AF guage.
The fuel map will most likley need to be re-programed because with an upgraded turbo you will be flowing more air so it will need more fuel, if this does not happen you hit fuel cut. Not good.
You should look into the subject a little more and find out exactly what you are planning on getting to make you 100hp extra.
Old 01-19-2004, 01:04 PM
kjewer1 kjewer1 is offline
AF - Advisor
You actually take fuel out as you move more air. Tuning is absolutely key to making big power, or just making the most of what you already have. Some people will run 14s with 20Gs, while others run 11s. The differemce? Tuning. Learn it, love it, live it.
If you decide that its time to tune the car, you will need something that will affect the airfuel ratio. This is typically an Apexi AFC. Could also be VPC, DSMlink, emanage, etc. Once you have control, you need to know what to do with it. A datalogger is the key ingrediant. Learning how to read it is the tricky part. Make your changes, then datalog again to see if you did the right thing. Lather, rinse, and repeat as necessary. Dyno time is helpful but not necessary, and a wideband is helpful but not necessary. I do 99% of my tuning on I495 on the way to work The track is my favorite place though, since you will see the results in your mph, and its cheap (unlike dyno time).
Learning to tune isnt hard, but it takes time. If you start with a small setup you can learn with relative safety too. This is why I recomend people get a datalogger as one of thier first mods if money allows, and start tuning on the stock turbo. Dont jump right into the massive turbos, since one small mistake can get ugly real fast at high airflow. There are several online resources to start with. In fact, there may be a sticky on the rko forums in my sig. Kyle (kpt...) put together a good one for a logger and AFC combo that is all over the internet.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-19-2004, 02:11 PM
Thanks for all the help
Old 01-19-2004, 02:13 PM
What kind of tuning would i be experimenting with? air/fuel and timing or are there other things to tune?
Old 01-19-2004, 04:45 PM
onespliffspyder onespliffspyder is offline
Good questions GSX88 this is something im also very interested in since i want more to make power but gradually, i dont wanna jump into anything and cause problems. What exactly is datalogging and how does the AFC work. Is there a site to learn about either one.
Thanks
Andy
Old 01-20-2004, 04:14 AM
AF - Advisor
Go to the rko forum site in my sig, and there is a sticky in the DSM section called "ultimate tuning/AFC guide" or something like that. Should be a good start.
Kevin Jewer
