Go Back   Automotive Forums Car Chat > GMC > Jimmy
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 01-18-2004, 08:56 PM
XtremeXP's Avatar
XtremeXP XtremeXP is offline
vacuum lines at transfer case 95 jimmy 4.3
Ok I just replaced a dry rotted vacuum line that goes from under the battery to the transfer case. Problem is I think I pulled one of the other lines loose from somewhere. Ok so one goes up under the battery. Another goes up to the vacuum tank I think. The last one goes to a y connector another line from the y connector attaches above the tansfer case and another (bigger) line goes from the y over the transmission pan and is hanging there with a little peice to put two hoses together in it. Where does this attach to? Anybody know?
Old 01-18-2004, 09:15 PM
Bronco2 Bronco2 is offline
Re: vacuum lines at transfer case 95 jimmy 4.3
The switch on the tranfer case has 3 ports. 1 goes to engine vacuum,1 goes to the accuator under the battery(to lock in the front diff.) -the other line tee's in with the trans and transfer case vent hose(to allow the accuator for the front diff. to release).Kind of a screwy system,but it works.
97 jimmy 4.3 vacuum diagram scottwmson Problem Diagnosis 1 12-07-2010 06:26 PM
Selling or Parting 93 jimmy 4x4 4.3 Votec(w) ibceng Classifieds 1 10-08-2009 03:34 PM
91 4.3 Injectors Will Not Pulse chaddeaton Problem Diagnosis 1 03-10-2009 05:33 PM
94 s10 blazer 4.3 high oil pressure chevyshitsonford Problem Diagnosis 4 03-08-2009 09:11 AM
PROBLEM now 98 blazer 4.3 v6 just replaced fuel pump smiley24 Problem Diagnosis 7 02-26-2009 10:45 AM
Closed Thread
