Old 01-18-2004, 08:29 PM
boosting20psi boosting20psi is offline
another question about the crankshaft pully
i got the center bolt off and the crankshaft pulley will not budge do i need to take the four allen wrench looking ones off or what? any help would be much appreciated thanks for all your help
Old 01-18-2004, 08:40 PM
89Turbo944's Avatar
89Turbo944 89Turbo944 is offline
Re: another question about the crankshaft pully
Yes it is the allen bolts that hold the pulley on. So you have to remove them before you can remove the pulley.
Old 01-18-2004, 09:15 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
mine were 12mm hex head! boosting20psi is your car a 1st gen?
Old 01-18-2004, 09:51 PM
it is a 90 GSX they are 6mm bolts
Old 01-19-2004, 01:15 PM
kjewer1 kjewer1 is offline
AF - Advisor
Just a note of caution. That larger center bolt also holds the timing belt sprocket to the crankshaft. If that should pull out of the tbelt, you are looking at a whole tbelt job as well Put that center bolt back in before you do anything else. The 4 smaller ones are what hold the crank pulley/damper to the tbelt sprocket.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
question about the crankshaft sensor. bmorebuick88 Park Avenue 1 10-01-2010 09:27 PM
Taking the crankshaft pully off a 1.3 cal058 Metro 4 11-10-2008 11:32 PM
another question about the lt4 hot cam 95LT1Z Camaro Discussions 2 10-10-2006 10:16 PM
And yet another question about the cooling system jimmy_h Century 3 06-16-2005 11:43 PM
another question about the coolant system epec Taurus | Taurus Wagon 1 09-21-2003 07:42 PM
