Old 01-18-2004, 06:25 PM
Gordito Gordito is offline
Removing Windshield Wiper arm from Shaft
I am trying figure out how to remove Windshield wiper arm from the shaft My driver side wiper broke loose from the linkage the arm is still attached to the shaft and I can't remove the arm from the shaft. The wiper arm looks like it is press fit on the shaft. I am wondering if I will have to replace the whole linkage assembly but I can't get the passenger side wiper arm off the shaft to remove the leaf guard assembly.
Old 01-21-2004, 03:59 PM
Sport45 Sport45 is offline
Re: Removing Windshield Wiper arm from Shaft
On my '96 I raise the flap covering the attaching nut. Loosen the nut until the shaft threads no longer show. Tap the nut with a rubber mallet while lifting on the arm. Usually pops loose with the first tap.
Old 01-21-2004, 07:03 PM
I saw in the repair manual how to remove by the method you mentioned but my wiper arm is pressed fit on a spline held in by a sliding clip whacked the heck out of it with a small hammer but it didn't budge so i took a hack saw accross the top split it open and finally removed it with a screwdriver without damaging the spline or shaft ...........
Thanks for the response
1990 Ford Probe Windshield Wipers Stuck Vertical Spidersquish Probe 1 01-25-2012 10:49 PM
Equinox windshield wiper blades Ruley73 Equinox 0 03-14-2010 06:57 AM
How to remove windshield wiper arms? mcryder26 Rodeo | Passport | MU 2 08-09-2004 08:59 AM
Removing Windshield Wiper arm from Shaft Gordito Caravan | Voyager 0 01-18-2004 06:20 PM
