Old 01-18-2004, 06:20 PM
darkside_027 darkside_027 is offline
Send a message via Yahoo to darkside_027
Post fuel injector problems?
I have a 1990 crx dx completely stock AT trans. It has a freshly rebuilt head. The problem im having is strange. It idles fine no miss or anything. I tach it up to about 3500 and the engine stutters a little. I drive it around and it has hardly no take off power and when i try to kick in the passing gear it does the complete opposite and boggs down. I am getting 2 codes. Code 1 (oxygen) and code 16 (fuel injector). It seems to be acting like its running off of one injector.The power has also went down alot. I would appreciate any help you guys can give me.
Old 01-18-2004, 07:22 PM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
i don't know about the codes but to me it sounds like when you give it the gas it stumbles, which to me means not enough fuel is being delivered.
maybe start off by trying some good fuel system cleaner in the tank, if that doesn't do it, start changing and checking each part, fuel filter, injectors, pump maybe.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 01-18-2004, 07:38 PM
Re: fuel injector problems?
Ill give it a try im running out of ideas with this car . Thanks for your help.
Old 01-19-2004, 07:04 PM
well i think i fixed it. The timing was off a little. Thanks for your help
fuel pump or fuel injector problem princess887 Focus | C Max 10 08-23-2012 06:21 PM
help! fuel injector problem Suzannes Caravan | Voyager 9 11-07-2009 01:06 PM
98 pathy fuel gauge problem akaesha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-28-2009 08:35 PM
Saturn ion fuel injectors problem Jimmy154 General Discussion 2 03-17-2004 05:54 PM
Fuel injector problem... Kenji_240SX 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 0 07-23-2003 09:29 PM
