Old 01-18-2004, 02:30 PM
skitzo315 skitzo315 is offline
Send a message via AIM to skitzo315
Angry 93 Escort No Heat
I have a 93 Ford Escort LX and I am not getting any heat. I had heat last winter but this summer I rebuilt the engine. New heater core, thermostat and waterpump. Come this winter I have VERY little heat. I wouldn't even call it heat. I replaced the thermostat once again to see and still no heat. I feel the hoses leading into the heater core and they don't feel hot or really warm. What is wrong with my car?
Old 01-18-2004, 08:08 PM
bustedratchet bustedratchet is offline
Re: 93 Escort No Heat
Does the upper radiator hose feel hot ? If not I'd suspect a defective thermostat. If it is hot try removing the heater core hoses and flushing the core with a garden hose. Give it pressure with 5 second bursts both ways and see what happens.
Old 02-01-2004, 04:01 PM
bebopinbill bebopinbill is offline
I am having same problem,have replaced thermostat, flushed rad and heater core , new antifreeze (50/50). My temperature gauge barely comes off cold. Placing the defrost fan on high on cool days actualy cools the engine temp. I am suspicious of the block in which the thermostat resides between the engine and the top rad hose. There is a small port beside the thermostat opening in this assembly which has like several small plugs visable from the exterior view. I do not know its function (temp relief, pressure relief, freeze relief,????) I suspect the engine rad fluid is bypassing the closed thermostat to the main rad. The top rad hose feels warmer than my heater core hoses. I am hoping someone out there knows the solution
Escort 99 keeps jumping on first drive of day for about 150 Yards (CEL 0401) MyEscort99 Escort 4 04-02-2009 11:11 AM
97 escort heat msdz Escort 4 11-23-2008 01:22 AM
99 escort heat?? barteldt Escort 7 11-13-2008 01:21 AM
93 escort Heating failure chap2000 Escort 4 02-07-2006 06:29 PM
'99 Escort heating problems..... cerati.z Escort 0 01-30-2004 02:38 PM
