| COMPLETELY off-topic Talk about anything other than cars. But you can't be mad and angry in this forum! |
ok... last night i installed XP. I have a compaq laptop thats kinda old... Everything is ok but my wireless router doesn't let me connect to the internet. (I'm on my roommates pc) It says that there is a conection & it knows its there but i can't get online.... I tryed to maybe uninstall it but I can't find anything that will let me do it.... any suggestions?
"Don't make someone your priority if they only see you as an option." |
Re: No Internet!!!
Might need a little more information before we can help. Do you have a pc and a laptop networked together with the wireless internet? Make sure you have the router connected correctly, and the pcmcia card in your laptop correctly. Than if that doesn't work uninstall the wireless devices and reinstall to make sure the drivers were correctly installed. But thats just a shot into the wind without more information. What operating systems are on the computers, are they compatible with the wireless devices that you are using? What do you use for a internet service provider?
![]() 95 Pontiac Trans Am SOLD 03 Chevrolet Cavalier SOLD 03 Mercury Sable |
Read the router manual and see there are any directions for configuring it via a web browser. If there are, plug in the IP address to a web browser on your laptop. If you get to a configuration screen you know that the connection between the laptop and your router is ok, but it needs to be configured differently.
Cloak's advise is good.. also running the internet setup wizard on a broken connection can sometimes restore it. Under XP to change hardware stuff, right click on my computer, then the hardware tab and device manager. Select the hardware item and hit remove... i think.. too lazy to go into other room. When you reboot it should find the new hardware.
Re: No Internet!!!
heina21:
Do you have an IP address? I find out, go into start > my network places. Find and click ONCE on your wireless card. In the mid-low left hand corner of the screen, does it say you have an IP address?
The name's Joe. Feel free to use it.
Re: No Internet!!!
ok... my roommate has the cable box & router in her room.... she has a pc... I have a laptop with the wireless...I did have 98 and it worked fine... but after I installed XP it doesn't want to work... it says its connect & it knows its there ... and I can't find a way to get rid of it... i'm going to see what I can do from what yall say....
Re: No Internet!!!
can't find the hardware tab... i dont see anthing like that at all
Re: No Internet!!!
What type of machine are you using? Does it have intergrated wireless, or do you have a card?
Re: No Internet!!!
I would start out with re-installing the card in just the laptop, chances are the pc and the router are configured fine if they've been working this whole time. XP is really touchy with wireless cards and I know alot of people have had trouble with it, I don't have XP running on my wireless network so I don't think I'm much help in this problem.
Re: Re: No Internet!!!
Or another option is to wait till service pack 2 is released and it will fix that problem and other associated problem. If there is any trouble relating microsoft problems, search their database first, in most cases a solution would have either been provided for you or you can lodge a technical support as after all you own a copy of windows thus your eligable for technical support from them. |
Re: No Internet!!!
After you install XP, especially the home version, if you have any devices connected your machine other than the standard Keyboard, Monitor, and mouse, it locks up the OS on its first boot. So for your laptop you should have taken out the pcmcia card before you installed the OS. After the OS is installed and you have booted it up and gone through all that other stuff, then insert your pcmcia card into the slot and XP should find it and allow it to work properly.
6spd Accord Sold, but you can still admire it, as I do, at http://rwagner42.brinkster.net/6spdaccord.htm 2001 S2000 Currently -- Comptech Intake, Neuspeed Springs, Neuspeed Cat-Back Exhaust, Air/Fuel guage, Nitrous Pressure Guage, TPS, Remote bottle Opener, 2 Step Colder Plugs, NX Wet 75 Shot, 4.57 Gears, 5% tint. 2005 Mustang GT: Working on C&L Intake w/ Tune, Pro Kit, Wet 75 shot. Shooting for Mid 12's. |
What kind of router do you have? Also, was Win98 hardcoded (IP and DNS put in manually) for your network settings or was it configured to use DHCP?
If your router has a web-based interface, then make sure your IP and DNS range is set to DHCP - or autodetect. Otherwise it'll see it has a connection, but won't be able to find the router. I think XP mucks with the network settings when you install it. Also, run the Network Wizard to tell XP you are setting up a home network through a router/gateway. This not only allows XP to set itself up for network sharing, but I believe will set all your settings back to DHCP (autodetect). Once in DHCP, depending on the router, you should be able to access the router's IP through your web browser if it has a web-based interface (such as Linksys routers). From there, get your network settings and either leave your PC in DHCP or hardcode the settings into Windows XP. Your router may also have a wireless security key (depending on the type of router you have) which you will have to input for your new OS to allow it work properly. It really just depends on how the router is set up.
![]() 1995 Honda CRX del Sol VTEC Manufactured: Suzuka, Japan Production Sequence #1269 Team Del Sol member #1131 HondaVision: Team Sol Forum - Home of Team Del Sol __________________ |
