Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 01-18-2004, 07:41 AM
gelcoman gelcoman is offline
Unhappy I need help......please.... v6 2000
Help.... I have a Chrysler Stratusyear 2000, its a v6 2.5L, convertible, autostick. Its simply grate, the motoris absolutly wonderful, but afther nearly 4 years i whould like to have more performance from it, but i have a problem, i havediscovered thatmy mototr is a eclipse v6 non turbo, year 2000, i think its called 1g something, i cant finde afthermarket parts for my lil baby, i am looking at everysingle option there is for this motor, chrysler and dodge whont help at all.
Can u guys help me? please its very important, i realy whont my car performing more ......
Please any help is welcomed, more technical specsi can getmore i can make it perfect!!
unfortunatly this car is not imported in the uk where i live.... well its a fortune....itsthe only one in the all uk!!!
Old 01-18-2004, 09:13 AM
johnnyBgood johnnyBgood is offline
Send a message via AIM to johnnyBgood
Re: I need help......please.... v6 2000
Well, if you have a 2.5L V6, that is not the Eclipse V6 motor. The eclipse V6 motor is a 3L.
What is the engine code? 6G72? if so, you can go to www.rippmods.com and get a supercharger system for your car. It has everything you need, from bigger injectors to fuel pump, even drive belt.
Old 01-18-2004, 09:28 AM
i dont know the codes, i know from the guys of chrysler convetible and stratusfere and from all par. com is a mitsu v6 2.5l, the baby version of the 3.0L, maybe it has ony the head that is different...with obviusly other major or not diff, like pistons etc etc... maybe im wrong, but it seems to me that from this motor has been deleted many hp, where to finde them?......
if it's not as they say a mitsu eclipse what the hell it is? i have found that mitsu have build it in one of his fabrics in usa using there bits and pieces...
ok lets say it is a mitsu engine, nobody can tell which version of which model?
Old 01-18-2004, 09:47 AM
Find out the engine code. Just telling me it a 2.5L really does not do alot. The code will be in your engine bay and probably on the back firewall.
Old 01-18-2004, 09:50 AM
ok pleasetell my where i can finde out where the code is? i can give u the model ... that is jx lb5h 7, more then that i need a hand....
Old 01-18-2004, 02:33 PM
call your dealer, they will know. Or look around in your engine bay on the back firewall.
Old 01-19-2004, 08:06 PM
Teastone's Avatar
Teastone Teastone is offline
I believe that the 2.5L (assuming that is a Mitsu engine in that 1G Stratus of yours) would be a 6G73.
6G72 = 3.0L V6, SOHC found in 2G Stratus R/T, Chrystler Sebring LXi, Eclipse GT/GTS, DOHC found in Stealth and 3000GT
Silver 2002 GT-Turbo
Old 01-19-2004, 09:51 PM
Rulez Rulez is offline
Send a message via AIM to Rulez
You are correct...its the 6G73.
Mike Rule
2000 Mitsubishi Eclipse GT Turbo
www.club3gfl.com
www.fiautosports.com
Old 01-21-2004, 08:45 PM
1gkiller 1gkiller is offline
the 2.5 is not a 6g72 motor......look on the left side fire wall or under the hood...it should tell u displacement and the engine code
