Old 01-18-2004, 04:54 AM
civic_racer_dualcb civic_racer_dualcb is offline
Supercharger setup
Ive got a 1990 civic 4door, have been toying with many ideas as what to do with the motor, there was b16, then vtec d series, build up the d15 ect but now i have some ideas for a draw though supercharger setup. The idea was to use a dpfi manifold, with the FI and throttle removed, a toyota 1gze supercharger sitting on top drawing though an SU carb. I was planning on running around 6psi. Anyone have any input into this?
Old 01-18-2004, 04:16 PM
alexdog69's Avatar
alexdog69 alexdog69 is offline
Re: Supercharger setup
how about... belt drive... throttle linkage.. fuel supply (a weber SU sidedraft carb wont like the psi currently coming out of the fuel line very much )... and well.. ignition timing... as the advance is ecu controlled... using carbs is fun tho... supposedly running 2 x 2 bbl sidedrafts on a honda engine can produce a lot of power and sounds utterly amazing at least within the realm of civic-tuning (relatively speaking y'know)
Old 01-18-2004, 04:46 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
sounds like fun project
Old 01-18-2004, 10:06 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
sounds like a neat idea, i look forward 2 pics of progress
Old 01-19-2004, 11:39 AM
alexdog69's Avatar
yeah it sounds like it could be pretty fun... i take it that you are planning on cutting the manifold apart so that you are using the runners and part of the plenum base for the SC to mount onto?
how serious are you about this particular config ? still just conceptualizing ?
the sidedraft SU would sure be fun but keeping the EFI can potentially make things much easier ... especially since running the OBD0 ECU you can use something like www.TurboEdit.org to manage your fuel enrichment and boost ignition retard.... perhaps you can just hack up a MPFI manifold to accept a SC and TB ... and basically make your own JRSC style unit... or you could just buy a JRSC or similar unit in the end it may work out to be cheaper and easier than hacking away so much of the existing "infrastructure" in the vehicle ....
Old 01-19-2004, 04:20 PM
90civicracer's Avatar
90civicracer 90civicracer is offline
Send a message via AIM to 90civicracer
Get a d16a6 and supercharge that.
***90 Civic EX 4 Door***
Ace$nyper: yea it did woo woo 4500 posts i should be ashamed *kills self*
90civicracer: haha you killed yourself you got
Ace$nyper: OMFG LOL that might be the funniest thing you EVER posted
bwhahahaha
