Old 01-17-2004, 01:58 PM
Roy 2 Roy 2 is offline
Talking Remove catalist
I live in U.K.. I have a 1999 Tahoe 2dr, 4wd, 5.7 vortec.
In the U.K. I have no need to run catalists in the exhaust system.
If I remove them and fit fire pipes, will this upset the sensors before and after the catalist?
Or, can I just leave the sensor after the catalist outside of the exhaust pipe after removing the catalist?
Old 01-17-2004, 02:13 PM
Bronco2 Bronco2 is offline
Re: Remove catalist
You will turn on the check engine lite and set a code
Old 01-17-2004, 02:22 PM
Re: Remove catalist
Thanks for letting me know what the resulting problem of removing the catalists will be.
Is there a way of removing the catalist without upsetting anything?
Can't see the point in shelling out for catalists when not required by law.
Old 01-17-2004, 02:46 PM
Re: Remove catalist
The only thing I can think of is a change in the PCM programing so it doesn't monitor cat. performance. I don't know if this is possible,but some of the after market electronics people may be able to help
Old 01-17-2004, 03:05 PM
Re: Remove catalist
Thanks for your input Bronco2
3.8 Intake Removal problem Jakal Park Avenue 2 05-23-2009 03:19 PM
'00 COUGAR removing dash gw84 Cougar 0 04-28-2009 08:08 AM
1994 b-3000 radio removal zoobag General Discussion 1 04-05-2009 05:22 PM
How To: Remove Door Panel LifeIsPain Montana/Montana SV6 1 03-21-2009 07:08 PM
