Go Back   Automotive Forums Car Chat > Honda > CL | Inspire | Saber | TL
Old 01-17-2004, 11:40 AM
rankinstunk rankinstunk is offline
Unhappy Anyone knows how to program a keyless entry remote for a 97' TL?
HI..
I need help programming the keyless remote cause i went to some place that repairs cars and they damaged my remote and they bought me a new one but they did not programmed it for me and here where i live it costs too much.
I need help trying to program mine please..
97' TL remote....help!!
Thanks for the help if u can
J.C.
Old 03-04-2006, 10:53 PM
cornman1972 cornman1972 is offline
Re: Anyone knows how to program a keyless entry remote for a 97' TL?
Hold Both the Lock & Unlock Buttons down together and the unlock and trunk button after that and that chould do it for you. I have a 1997 CL and had a simmalar problem.
Old 03-06-2006, 10:33 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
INSTRUCTIONS
1998 2.5TL with factory-installed security
system
1996–98 3.2TL with factory-installed security
system
Programming the Transmitter
NOTES:
• This system accepts up to two transmitters.
• Entering the programming mode cancels all learned
transmitter codes, so none of the previously
programmed transmitters will work. You must
reprogram all the transmitters once you’re in the
programming mode.
1. Open the driver’s door.
2. Push up the driver’s door master power door lock to
the unlock position. Hold it there for the rest of this
procedure.
3. Insert the key in the ignition switch, then remove it.
Repeat this four more times within 10 seconds.
(Steps 3 and 4 must be completed within 10
seconds, or the system will exit the programming
mode.)
4. Insert the key in the ignition switch. Make sure the
power door locks cycle to indicate that the system
has entered programming mode.
5. Press the “LOCK” or “UNLOCK” button on the
transmitter. Make sure the power door locks (all
except the driver’s door) cycle to indicate that the
transmitter has been accepted.
6. To program a second transmitter, press its “LOCK”
or “UNLOCK” button within 10 seconds.
7. Release the master power door lock switch to exit
the programming mode.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
