Old 01-17-2004, 10:48 AM
Hirx Hirx is offline
Send a message via AIM to Hirx Send a message via Yahoo to Hirx
Does anyone know how to bleed a clutch? -URGENT
Hi, I have a 92 honda accord and I just replaced the clutch master are slave cylinders. The problem I am having now is on how to bleed the clutch system.
I hooked up a hose to the bleeder screw on the slave cylinder and put the end in a jar 1/2 filled with brake fluid (DOT 3) and made sure all bubbles were gone before tightening it.
I tried all night, but was unsuccessful, my clutch still will only stay at the top or the bottom and there is no resistance when I push it just snaps down.
Is there something I am missing here? Any help would be greatly appriciated. Thanks in advance!
-Paul
Old 01-18-2004, 12:08 AM
whyte Gsr b0i's Avatar
whyte Gsr b0i whyte Gsr b0i is offline
Send a message via AIM to whyte Gsr b0i
Re: 92 accord bleeding the clutch?
keep on pumpin.. pump in and then tighten.. pull the pedal out the loosen.. pump and tighten.. pull pedal.. repeat making sure the clutch fluid resivor is full.. then after doin that maybe ten times you should have pretty much need clutch fluid all thru the lines.. tighten the the bleeder.. then then pump in and out.. pull it out if you have to.. just keep pumping.. make sure the resivore is full.. and not sucking in air... hmm... if this doesnt work i'd say there is something wrong with the CMC (clutch matser .. blah) pull it off and check it out.. see if its pumping and sucking in the fluid..
97' talon Tsi fwd..
Rebuilding the engine.. should be running atleast 14.5 stock when i get that whip back together
'94 accord Lx coupe swaped ta Vtec...
1/4: 15.1
MODs: custom CAT.. VERY highflow.. Theres no Replacement for displacement.. and add me.. you can have times liek this too
90% driver 10% car
Nom'tawkin'bout
Old 01-18-2004, 12:09 AM
Reservoir** for the places i miss spelled it...
97' talon Tsi fwd..
1/4: 15.1
90% driver 10% car
Nom'tawkin'bout
