Old 01-17-2004, 03:40 AM
acgr76 acgr76 is offline
Send a message via MSN to acgr76
Angry starter problems
hi, i have a 1981 chevrolet scottsdale 4x4 pickup, automatic transmision, V8, i'm having problems with the starter i have changed it 3 times and it keeps breaking down, can it be an electrical problem or a distance problem??
And what is the clasification c/k?, 10/20/30?, 1/2-3/4 tons?, chevy/chevrolet/GMC??
Old 01-17-2004, 04:53 AM
Twist'n-Wrenches Twist'n-Wrenches is offline
Re: starter problems
acgr76 the starter problem you are having could be a heat problem as gm starters do not like the engine heat at all. This is called heat fading it is quite common problem in chevy race cars where the heat is extreme. You may also have an engaging problem with the starter if the starter drive engages to deep into the flywheel it will stick on and prematuraly where out your starter you will need to check the starter-flywheel clearance on that one. Need to know more info to help with your problem. As for the c/k. C stands for Chevrolet, K stands for GMC, 10 is a 1/2 ton, 20 is a 3/4 ton, 30 is a 1 ton in the chev line. In the GMC line they are as follows 15 is a 1/2 ton, 25 is a 3/4 ton, and 35 is a 1 ton. Then there is the s-series as in s-10 and the s-15. good luk
Old 01-17-2004, 04:26 PM
comp comp is offline
3 time in how long? sence 81 isn't to bad do you have the torque
convertor shield on, it helps keep dirt and other things out of everthing under there, are you breaking nose cone's, grinding the teeth off of the
starter? what do the teeth on the flywheel look like,
Old 01-17-2004, 11:48 PM
thanks!, and i have changed the starter 3 times in 6 months and the flywheel 2 times, i think the starter and the flywheel are too far apart because half of each teeth in the flywheel is damaged, how can i get them closer?
Old 01-17-2004, 11:57 PM
shim's didn't some come with starters, parts guy didn't ask
i need to check but the clearence should be 1/16" sounds like your is
1/8" or more
Old 01-18-2004, 12:36 AM
thanks i'll try using the shims
Old 01-18-2004, 04:12 PM
grimesjm1 grimesjm1 is offline
Send a message via AIM to grimesjm1
c/k---i thought c was 2wd and k was 4wd? I have a chevy K1500, it's 4x4........
Old 01-19-2004, 11:05 PM
zeeb zeeb is offline
With half the teeth ground off of the flywheel, you are probably looking at replacing it (again...)
Also shims arent gonna get you closer...they make the distance bigger. Are you sure you have been getting the correct starter? (and flexplate for that matter..)?? If it is wearing off half of the tooth width it makes me wonder..
As far as i know C/k... C= 2wd K=4wd
Old 01-20-2004, 06:57 AM
michelq michelq is offline
you need cast iron starter bell housing it well fix your problem for sure
Old 01-20-2004, 04:30 PM
72 rs's Avatar
72 rs 72 rs is offline
make sure its the right starter first. they make 2 diff ones for that truck (73-87) itall depends on wether or not it was made in a USA plant or MEXICO plant. USA models use whats callaed a standered starter, MEXICO models use a metric starter. FYI when replacing the starter a tail, tail sign that u have the wrong starter would be......
metric starters have a knurled bolt shank and are larger in diameter.
standerd starters have smaller bolt diameters.
.... so u can put a metric starter on a USA truck......problem is itwont line up.
......u cant put a standered starter on a MEXICO truck.....bolts wont go throuh the holes.
also shims WILL move the starter closer/further from the flywheel, flexplate. cut the shim in half.....inside hole will move the starter away from..... placing them in the out side hole will move it closer.
Old 01-20-2004, 05:16 PM
72 rs ,, are you talking about the staggered & straight bolt patern?????
Old 01-20-2004, 08:17 PM
72 rs's Avatar
ive never had a prob. with the straight bolt pattern. im refering to just the staggered bolt pattern. i know they used these 2 diff. starters on more than just these trucks. it took me forever to find this out own, through trial and erorr of course. if you put whats called the metric starter (has larger bolt holes) on the motors assembled in the USA they dont fit right. being that the holes are larger (due to the larger diameter ofthe metric bolts) the standered bolts have play causing the starter to miss align.
Old 01-21-2004, 01:36 AM
i'll try using a shim on the outer hole tomorrow and see what happens, i got 1/8, 1/16,1/32 and 1/64 shims...
Old 01-21-2004, 01:46 AM
72 rs's Avatar
hope it works out!!!
Old 01-21-2004, 04:56 AM
i have also had "milled " heads on a few, they were milled on the surface that bolts against the block??? don't know if it was factory or
not but i have seen they where 1/16-1/8" thinner, may have been a
bad run at factory and they did to save a few "thosand" of them
