Old 01-16-2004, 04:20 PM
GARY HOFFBAUER GARY HOFFBAUER is offline
Unhappy 5.3 Rough Idle - But No Ecu Code
I have 2000 Tahoe with 5.3 with 63k miles on it. For last 1,000 miles the engine idles rough when warmed up with tranny in drive. BUT NO "CHECK ENGINE" CODE IS TRIGGERED. Twice in last 2 weeks I have had injectors cleaned (at 2 different shops...one a Chevy dealer). The throttle position sensor (TPS) checks out OK. The Idle Air Control Valve above it also checks out OK. The fuel pump was also replaced because of unstable fuel pressure. The rough idle is better now...but NOT totally smooth like it used to be. ??? Again...NO ENGINE CODES TRIGGERED. Any suggestions?
Old 01-29-2004, 11:36 AM
jthomp2377 jthomp2377 is offline
I have a 2001 Tahoe with 39,000 on it that is idling rough as well as it did the same thing around 28,000 on it. The cure was to clean the throttle body air intake butterfly valve.Carbon deposits get on the edge of the butterfly valve allowing too much air and computer has a hard time adjusting for it. Just remove your air intake housing and spray up in there. Don't flood it. The engine may turn over a few times before starting, compensating for all the fluid, but will burn off. Good luck, let me know how you make out.
2003 F150 Supercrew V8 5.4L rough idle making popping sounds pat53 F Series 5 11-12-2009 06:30 PM
96 Cutlass Supreme w/ Rough Idle, but drives good chrisluna Cutlass Series 1 09-17-2009 07:29 AM
Rough Idle Mayathebee Cougar 1 03-22-2009 08:23 PM
2000 5.3 rough idle when warm busta Silverado 0 11-03-2004 10:39 PM
5.3 Rough Idle - But No Ecu Code GARY HOFFBAUER C/K 7 09-04-2004 10:07 PM
