Old 01-16-2004, 01:24 PM
kvin002 kvin002 is offline
1st generation tranny in 2nd generation
Hey everyone,
This might sound like a dumb ass question but i dont know the answer to it. Will a 1st generation tranny fit in a 1995 eclipse?? Its from a 92 eclipse gs 2.0 and the other is a 1995 eclipse gs 2.0
Old 01-16-2004, 01:35 PM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
Re: 1st generation tranny in 2nd generation
No it will not fit. The motor in your 1995 is a 420a (chrysler). The 92 is a NA 4G63 completly diffrent motors.
Old 01-16-2004, 04:41 PM
Afrokid's Avatar
Afrokid Afrokid is offline
Send a message via AIM to Afrokid
correct me if im wrong, wont the tranny work if u have a 97 4g63 engine and swap it for a 94 4g63 engine? both turbo charged.
"Cant you see that your smothering me, holding too tightly, afraid to loose control cause everything that you thought i would be, is falling apart..right in front of you....every step that i take is another mistake to you, and every second i waste is more then i can take"
Old 01-19-2004, 01:47 PM
kjewer1 kjewer1 is offline
AF - Advisor
Nope. The 2g has the front and rear motor mounts on the tranny. The 1g puts the front and rear motor mounts on the block, so the tranny wont have any mounts. You might be able to get a 2g tranny in a 1g, but not the other way around. Now, I believe it was sean caron that did put a 1g tranny in a 2g, but he had to weld up all the mounts. Who needs the hassle.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-19-2004, 04:53 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
are you sure thats not the other way around... cause when i just pulled the motor in my GST the mounts that were on the block was one on the drivers side and one in front... and the 2 that were on the tanny were one on the back and one on the passenger side! i dont get it
Old 01-20-2004, 04:13 AM
AF - Advisor
On a 2g the front mount is on the tranny. On a 1g the front mount is on the block. Its just the way it is
Kevin Jewer
Old 01-20-2004, 07:58 PM
EclipseRST's Avatar
Banned
ok here is the top view of my motor before i pulled it... the first pic on the page! if you enlarge it the motor mount the sits on top of the crossmember is right under the left corner of the valve cover? so if it was on the ranny wouldnt it be over another 6 inches to the left? sorry i'm not tring to prove you wrong but i still dont get how that is on the tranny! http://www.cardomain.com/memberpage/496801/2
Old 01-20-2004, 09:43 PM
AF - Advisor
Its on the tranny Part of the illusion is the angle at which the picture was taken.
Kevin Jewer
Old 01-20-2004, 09:53 PM
EclipseRST's Avatar
Banned
DAMN YOU!! i just drove 15 minutes to the garage that its in to try to prove you wrong! but no!!!! you were right, you can also see it in the first shot of the crankshaft! man am i blind!
Old 01-21-2004, 02:26 AM
AF - Advisor
hehe. Its all good. After working on dozens and dozens of 1gs and 2gs, things like that are burned in my mind forever. But I do still mix things up every now and again. Not this time though heh
Kevin Jewer
2ND generation rx-7 --- v-8 conversion kit. kcxox RX-7 171 09-03-2009 02:27 PM
1st/2nd Generation timd 2nd Gen 00-05 1 06-18-2009 08:07 AM
1st generation, 2nd generation auroradream Aurora 1 12-21-2003 01:09 PM
cost of a new 2nd generation engine? wangtang RX-7 1 07-05-2002 01:18 PM
advice on 2nd generation Legend? csieminski Legend | RL 3 03-13-2002 10:40 AM
