Old 01-16-2004, 09:44 AM
jayballa305 jayballa305 is offline
Send a message via AIM to jayballa305
Question can u switch from automatic to manual transmisson?
I got a 91 civic sedan.I want to throw a integra Ls engine w/ manual tranny.If anyone has done it or know some one who has done it or just swithed over to manual on a 88-91 civic please reply.If that iz possible after i switch engines i going to throw a vtec head "gsr' on it.It should produce 190 hp but in my light civic it will do more damage.
Old 01-16-2004, 10:04 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Re: can u switch from automatic to manual transmisson?
yes...you can do an auto to manual swap - they are not cheap if someone does it for you...but other than a pedal set, cutting a hole in the firewall for the cable, you should be about set
CWBETB has done the auto/manual conversion - he has way more details than i do.
Welcome to the board
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 01-16-2004, 10:29 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
Re: Re: can u switch from automatic to manual transmisson?
no he doesnt b/c he paid someone to do it! haha..
SOLD!
Old 01-16-2004, 11:06 AM
spongerlbc's Avatar
spongerlbc spongerlbc is offline
Send a message via AIM to spongerlbc
You dont have to cut a hole for the clutch cable....there is already a hole in the firewall. I would explain but: http://hometown.aol.com/jrmupzaii/auto2man.html does a pretty good job (and wow look at that it came from the FAQ at the top of the forum). Its a pretty straightforward swap with the worst part being the pedal assembly as you have to remove your dash to get it out / new on in.
DOHC ZC 89 DX HATCH
Old 01-16-2004, 11:09 AM
sastanley's Avatar
AF Premium User
ha..right...good point Jason
I'd hope he'd have a parts list or some shit.
Nice data on the firewall...I have removed a Civic pedal assembly and it is a pain, as noted above. I was pulling it from a wrecker yard, so i didn't have to be too careful, but you can't even access the bolts to remove it until the dash is out..
I'll make one up, peeps can add to it:
manual pedal assembly
clutch cable
linkage
shifter
manual console
this list assumes some more obvious things are taken into consideration like a manual tranny & ECU with the swap.
You'll also have the shift linkage since you are going to a b-series motor, and a d-series manual linkage wouldn't fit anyway
-Shawn
'91 Civic DX sedan
Old 01-16-2004, 02:17 PM
spongerlbc's Avatar
You will also need the rear tranny mount and the rear mount that attaches to the rear X-member as it is different. You will also need a starter from a manual tranny (along with both bolts), and if the engine doesnt come with the flywheel, clutch, and pressure plate assembly you need the 6 flywheel bolts (as they are different than the manual) and the 6 clutch bolts. I ended up getting raped for $72 from Honda for the 12 of them. Covering up the holes left over from the auto shifter is also fun (I refused to use self taping metal sheetscrews so I put down a layer of metal and fiberglassed over it as a temporary solution till this summer). The only complaint I have is that the shifter feels loose (I can move it side to side 3-4" when its in gear), but it works and theres snow on the ground so theres nothing I can do about it. By the way, how loose does a stock shifter feel? Never driven stick before so I have nothing to compare it to.
DOHC ZC 89 DX HATCH
Old 01-16-2004, 04:04 PM
88CRX's Avatar
88CRX 88CRX is offline
I had it done on my crx.... and i payed about $800cdn total... parts and labour.
zc powa
short ram intake
dc sports header
2.25 Magnaflow exhaust
h/r race springs
Old 01-16-2004, 04:15 PM
joebowlr21 joebowlr21 is offline
Send a message via AIM to joebowlr21
Wut year LS motor?? 90+ or below???
You are going to need the pedal box, ecu,shift linkage,cluth cable, axles with intermediate shaft, and rewire everything. Let me tell ya, wiring is the b!t$h part.Oh yea you are going to need new motor mounts.
We took a 90dx crx automoatic and swapped in a JDM DOHC zc (official ZC not an ls block) with the DOHC tranny with an Si ECU.motor drop in was simple once we got the correct mounts from an Si but the wiring was anoyying. Took about 5 hours of wiring before it was started. only prob. we had was finding an intermediate shaft for the ZC. took awhile but finally found one at hasport motors.
I would also change all the basics before you put in the new motor I.E-
timing belt
plugs
wires
cap
rotor
thermostat
all gaskets (head,oil pan etc)
radiator hoses
Old 01-16-2004, 04:27 PM
spongerlbc's Avatar
The wiring is very simple, just follow the directions on fourthgenhatch.com . He made them even easier to understand. I am in the process of simplifying it even more. Oh, I followed his directions for MPFI and ZC swap (along with the auto to manual wiring that are in the link I posted) and it started the first time I turned the key.
DOHC ZC 89 DX HATCH
Old 01-16-2004, 06:52 PM
SiZ's Avatar
SiZ SiZ is offline
I payed an extra $500 cdn. to have mine converted from auto to manual when I had my B16 swap done.
"The nympho of info, I'm fuckin' what ya heard"
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
