Old 01-16-2004, 09:34 AM
moeandco moeandco is offline
Misbehaving Horn
When it is cold and I start my car the Horn blasts a few of times and the Hazard Lights flash a few times and stops once the car is going. The amount of times depends on how cold it is. What should I be looking for to fix this problem? The car is a 95 kia Sephia. It has an "anti-theft" mechanism that is supposed to cause the horn to honk and the lights to flash if the stereo is ripped out. I think it has got to be linked to that but why does it happen only when it is cold?
Thanks.
Old 01-17-2004, 03:13 AM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
Re: Misbehaving Horn
check the wiring.
Mustangs are nice, but I'd rather have one of these...
Old 01-18-2004, 01:42 AM
matada's Avatar
matada matada is offline
Send a message via AIM to matada
You can try and pull thefuse to the stereo. If the security system is wired through the same circut, this should remove electrical power to it. If the problem stops, you have found your culprit. Make sure the security system does not have its own fuse. If it does pull both. Put the stereo one back in first. If the problem persists, it is the stereo. If it ceases, it is the security system.
Count em.....
matada19: she die?
OoToksinoO: no, unfortunately
matada19: damn
OoToksinoO: cant win em all man
matada19: can i sig that?
