Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 01-16-2004, 08:13 AM
motormike40 motormike40 is offline
Send a message via AIM to motormike40
which motor is better for boost
which is a better motor to boost. A stock LS or a LS/vtec with type R head on it
Old 01-16-2004, 08:36 AM
MastaCivic MastaCivic is offline
If you were going to choose between those 2 engines I would go with the LS becuase you can push like 10-12 pounds of boost on stock internals. With an ls/vtec your compression will rise because of the vtec head, so you will have to lower your compression with low compression pistons and all that other good stuff before you push more than about 8 pounds.
Old 01-16-2004, 09:30 AM
Re: which motor is better for boost
thx man
Old 01-16-2004, 07:23 PM
darkerdayz darkerdayz is offline
Send a message via AIM to darkerdayz Send a message via MSN to darkerdayz Send a message via Yahoo to darkerdayz
i have to disagree. i was reading up one day and i saw in import tuner's power pages, they did a ls/vtec. they then boosted both motors @ 10 psi (ls and ls/vtec) and the ls/vtec made over 50 more HP at the wheels. here is the link so you can see for yourself.
http://www.importtuner.com/tech/0104it_frankenstein/
friends don't let friends drive stock
Old 01-17-2004, 07:52 AM
Bambooseven's Avatar
Bambooseven Bambooseven is offline
the LS/V will make more power, the LS will be FAR more reliable
MY CAR!
Old 01-25-2004, 07:46 PM
dampachi's Avatar
dampachi dampachi is offline
Banned
Send a message via AIM to dampachi Send a message via MSN to dampachi Send a message via Yahoo to dampachi
well as far as reliability...once you affix a turbine to your engine and boost it 10psi...there goes your reliability regardless of the engine...but anyway I'd probably go with the frankenstein..but I'm gonna go throw shit in the game and pick something that wasn't one of the choices and that being a B18C1.
Old 01-26-2004, 12:19 PM
boosted331 boosted331 is offline
The classic example of "I don't know what i'm talking about, but I heard something in a magazine so i'll make something up that sounds reasonable in my head and tell this guy what to do" IF YOU DON'T KNOW WHAT YOU'RE TALKING ABOUT, DON'T GIVE A GUY ADVICE ON SOMETHING HE'S GOING TO SPEND MONEY ON!
Stock LS compression is 9.2:1. Compression with a B16 head would be 9.55:1, compression with a GSR head would be 9.73:1. Either of those are perfectly safe to run with 10 pounds of boost. The Vtec head flows a lot better, and will let you rev higher, and make a substantial amount more power. GSR's make more power stock and turbo for a reason, and the biggest reason is the head.
Old 01-26-2004, 01:42 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Thank You!!!! Finally.....
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
