Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 01-16-2004, 07:42 AM
motormike40 motormike40 is offline
Send a message via AIM to motormike40
Ls/vtec turbo
im going to turbo an ls/vtec. the heads are gong to be type r heads. will it raise the compression? can i still push high amounts of boost through the motor??
Old 01-16-2004, 12:35 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: Ls/vtec turbo
noooooo hi compression isnt turbo friendly the lower the compression the more boost it can take.. with a stock internal you may only boost up to 10-12 psi saftly but 8 psi daily driven..
1
Shift_BOOST
97 s14
Old 01-17-2004, 07:59 AM
Bambooseven's Avatar
Bambooseven Bambooseven is offline
Re: Ls/vtec turbo
if you have LS pistons still you'll be alright, but if you swapped the pistons to B16, or B18c1/5 pistons I wouldn't boost it unless you rebuild that bottom end for boost.
MY CAR!
Old 01-17-2004, 11:39 PM
turbo2nr's Avatar
Re: Ls/vtec turbo
ls pistons still can talke more the 12psi and the rods are still weak so i still wont boost over 8 psi daily driven
1
Shift_BOOST
97 s14
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
