Old 01-15-2004, 08:52 PM
Aaron1984Z Aaron1984Z is offline
Send a message via AIM to Aaron1984Z
Unhappy 95 Taurus Speedo Problem?
Hi I am new to the forum and i was hoping for some advice any help would be greatly apprechated...
I recently bought a 95 Taurus SE 3.0 v6 89,900 miles. I've noticed when driving on the highway the speedometer is totaly unreliable it jumps from 45 to past 85( speedo only reads up to 85) it also makes a kinda of ticking noise? I am hoping someone might have a possible solution to this problem i have had it to the tranny shop and they told me it wasnt on that end of things PLEASE help.
Thanks,
Aaron
Old 01-21-2004, 02:16 PM
mikeemon's Avatar
mikeemon mikeemon is offline
Re: 95 Taurus Speedo Problem?
If it is a mechanical spedo,(there is a cable) most likely the cable should either be lubricated or replaced.
Old 04-18-2004, 11:56 PM
mlessmann mlessmann is offline
Send a message via Yahoo to mlessmann
Question Speedometer issue on Ford Taurus 1995
I do have the same issue on a 1995 model and I can't believe that it is a cable issue as the noise related to the issue comes from (behind) the speedometer display!?
Old 04-19-2004, 01:52 PM
mikeemon's Avatar
Then don't believe it, what do I care. You may have a different problem. Try and replace the speedo if you want.
Old 04-26-2004, 01:56 PM
jellyring jellyring is offline
i have similar problem mechanic advised to replace upper speedo cable ther are probably 2 on your model upper and lower common problem location lower to transmission housing difficult to get at unless its really making you nuts lvtthefculone probably had transmission work or swapped out taurus model crap transmissions are notorious about fords F/ ix o/r r /epair d/ aily
Thanks,
Aaron
Old 04-26-2004, 01:57 PM
doworryboudit
Old 05-01-2004, 08:02 PM
JimLev JimLev is offline
The 95 should have an electric sensor (VSS) to send the speed signal to the computer and speedo, my 93 did.
It is in the transaxle. When bad the speedo jumps all over the place and can also make the tranny shift up and down on it's own, even if you are going at a steady speed. Sometimes the cruise control will stop working, as it gets it signal from the VSS also.
Old 06-10-2004, 01:31 PM
dembinsts dembinsts is offline
VSS may affect shift, but I have a similar issue with (mechanical) speedometer. Noise seems to be "in" speedometer. Speedo shop says these speedos were poorly built with cheap parts that wear out. Says speedo need refurb. THAT'S the probable issue re: speedo. Shifting may be VSS or TSS.
1999 Ford Taurus - Alternator Problems? Please help! johnosbourn Taurus | Taurus Wagon 11 05-18-2014 12:11 PM
2002 Taurus No Start fugiman852001 Taurus | Taurus Wagon 1 09-11-2009 06:20 AM
Taurus transmission light and problems mikecorki Taurus | Taurus Wagon 4 06-01-2009 06:39 AM
1997 taurus speedo and tach slimslopp Taurus | Taurus Wagon 1 08-08-2008 05:46 PM
1995 Taurus wagon speedo problem Slick Willy Taurus | Taurus Wagon 3 07-14-2008 04:28 PM
