Old 01-15-2004, 06:52 PM
cindylou cindylou is offline
drl bulb removel?
96 silveraldo,how do you get to the bulbs to check?where is the fuse under hood?can't find in box.
Old 01-15-2004, 08:46 PM
tidalcock tidalcock is offline
Re: drl bulb removel?
fuse for lights is probably under the dash. You can buy a Haynes repair manual at an auto parts store for about $15 and it should tell you how to access the bulbs. Or you can likely check one out at the local library for free. Good luck!
Old 01-16-2004, 09:14 AM
BigRed04Silverado BigRed04Silverado is offline
You have to remove the main headlight housing. There should be an "L" shaped pin that you pull out and the housing will come right off. Just be careful not to tug on the wires to hard. You should be able to reach your DRL bulbs from there. I have big hands and I could do it. There is a small tab that needs to be pushed on the bulb housing and then you can just turn them until they come loose. Hope that helps. You can also try finsing a owners manual. Direction will be in there as well.
Later.
Sean
Red 04 Silverado 1500 4x4
6'' FABTECH Full Suspension Lift
BFG TA KO Tires
American Racing Dimond Series wheels
Flow Master 40 Series dual with 18'' stainless slash cut tips
Drop in K/N
Tinted Windows
Old 01-17-2004, 09:31 PM
drizler drizler is offline
There Is An Online Chilton Manual
Check out the free online chilton manual. Its not the best but seems to cover most of the bases and the price is right, just a little ponderous to deal with .
