Old 01-15-2004, 04:08 PM
Purple5thgen Purple5thgen is offline
Question What mods do i get?
OK first off I have a puprle 5th gen civic vtec. All stock in the motor, but It's lowered with H&R springs and rims. My question is what can i do to make it faster without getting a swap. I know intake headers and exhaust. But what else is there?
Old 01-15-2004, 07:34 PM
Smokn91HB Smokn91HB is offline
Send a message via AIM to Smokn91HB
Re: Re: What mods do i get?
forced induction!... get a turbo set up you'll love it! i have a 91 hb it used to have a turbo on stock d15 i ran 16 psi through a bone stock motor (believe it or not) im serious i wouldnt reconmend doing it b/c after a year of abuse it blew up ( threw a rod) but that thing pulled [email protected] MHP at the local track... yours is a 1.6 SOHC vtec i assume so i would turbo it and run about 8 psi your 1.6 will handle it with no problem their bottom ends are fairly strong. you will love the performance you get out of that motor...
Old 01-15-2004, 09:26 PM
defman's Avatar
defman defman is offline
For a cheaper solution, Get you ecu programed, Bigger fuel rail and injectors, or even Nitrous Oxide. Although if you go with nitrous i would recommend keeping it between a 50-75 shot seeing as you have a stock d16z6 i'm assuming
Old 01-19-2004, 12:08 AM
getting bigger injectors and putting them on a stock motor is pointless.. getting a fuel rail and bigger injectors wont do anything but add more fuel.. which is only useful if he puts nitrous or turbo or supercharger or builds a motor or somthing...
