Old 01-15-2004, 10:10 AM
LT1fan LT1fan is offline
Send a message via AIM to LT1fan
Putting in a 350
I currently have a 1984 305 and am going to upgrade to a 350, I was wondering what all I need to worry about replacing. And if there is any worries about ruining something because I'll have more power.
Thanks in advance for taking for taking the time to read this
LT1fan
Old 01-15-2004, 10:40 AM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: Putting in a 350
so you have an 84 camaro?
Old 01-15-2004, 02:33 PM
Yep an '84. BTW I love your rims.
Old 01-15-2004, 07:22 PM
hey thanks, yea you shouldnt worry about your rear end and everything, my car came with a 2.8 and the rear is holding up fine, i have a worked 350 in it but its tearing up my 700 r-4, but i never liked the 700 r-4, i got a th-350 im puttin in this winter, if your putting in a somewhat stock 350 you dont need to worry much about all that,
Old 01-15-2004, 08:49 PM
victimizati0n victimizati0n is offline
Send a message via AIM to victimizati0n
I would try and Bore it out to see how far you can get, will same some money.
Old 01-15-2004, 10:32 PM
Re: Re: Putting in a 350
60 over, i would like to get a motown block, and build a sb 454!
Old 01-15-2004, 10:51 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
running gear for the smaller engines is identical to the stuff used for the 350. so they will hold up just fine. as far as the 700R4, i have never had a problem, and just had my new one built to B&M specs with a stage two shift kit and a corvette 1st-2nd servo. havnet put it in yet. but soon also, the 305 is externaly identical to the 350, so everything will swap right over. unless you use the 350 from a different era, you have to make sure the intake bolt holes are the same. in your case, anything before 87 will be safe.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 01-15-2004, 11:31 PM
dont get me wrong i like the 700 r-4, they got an awsome 1st gear, you jus cant really build a tough 700 r-4 that will last backing a high horsepower motor
Old 01-15-2004, 11:39 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Re: Re: Re: Putting in a 350
Thats why you get a built BRF code 200-r4 that is beefedup for a turbo buick. Way stronger than a 700-r4 and takes less HP to turn. Also you getto keep overdrive . They had the BRF 200-r4's in the Turbobuicks, and that black 454 sport truck form the early '90's
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 01-16-2004, 07:21 AM
Jays76Camaro Jays76Camaro is offline
Send a message via AIM to Jays76Camaro
LT1fan
Hey good luck with it - I had a 305 in my 76 and i pulled it for a 350/th-350 combo - I needed a new fly-wheel, starter (actually I needed one because of the headers I put on), driveshaft (my 2.73 rear was fine), torque converter, and a new shift cable and carb throttle connection
Sounds easy but it isn't always
I want my car to look nice for the womens
