Old 01-14-2004, 07:16 PM
quansak quansak is offline
Send a message via Yahoo to quansak
Lock is locked!!
My drivers side lock is jammed because I was trying to unlock it and pull handle at the same time ( bad habbit ) My power lock works on the other 3 doors, but I cant even lift up on the drivers side lock. The only way to get in is from the outside and thats after forcing the key to turn. It goes back down after I take it out. What could be the problem and how hard is it to take off my door panel? HELP ME!!
BTW- its a 94 Honda Accord
QS~
Old 01-14-2004, 08:09 PM
starkfu's Avatar
starkfu starkfu is offline
Send a message via ICQ to starkfu Send a message via AIM to starkfu Send a message via Yahoo to starkfu
Re: Lock is locked!!
sounds to me like you either bent a rod, or more likely the plastic where the rod mounts to, you would need to take the door panel off to inspect it, the panel itself isn't that hard to take off, there are some hidden screws, and you can easily break it.
***If knowledge is power, then a god am I***
<<former PH abyss member>>
1991 Acura Integra GS mods:
Tokico Illuminas
Eibach Sportlines
ES bushing kit
Mugen RTA bushing
Sprint RCA bushing
Power slot rotors and EBC pads
Gutted
Blown motor
Looking for B18C5
1994 Honda Accord EX
KYB AGX
Eibach Sportlines
Alpine CDA-9835
Just bought this car, more to come.
Old 01-14-2004, 09:05 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
I'm in the same boat, got in, got behind the plastic, can't see much back there, but I was wondering, what exactly am I looking for?
www.cloudcity.deviantart.com
Old 01-14-2004, 09:14 PM
starkfu's Avatar
you are looking to make sure that the lock rod is seated properly and that the plastic where it mounts to the lock cylinder isn't warped or discolored, also the rods should be placed in their respective guides. I don't have any pics, but if you've ever seen plastic bend it will look like that, look at the lock cylinder at the back of the door and where it mounts to the lock switch and the keyhole.
Tokico Illuminas
Eibach Sportlines
ES bushing kit
Mugen RTA bushing
Sprint RCA bushing
Gutted
Blown motor
Looking for B18C5
KYB AGX
Eibach Sportlines
Alpine CDA-9835
Old 01-24-2004, 02:50 AM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
when taking the door panels off it's best to start at the bottom, and if you have manual windows you should use a pair of needlenose pliers, or screwdriver to remove the hold in ring. start from the bottom with a flathead screwdriver, and pry the bottom of the door cover up, there should be a number of plastic pop rivets up until you get to the top of tyhe door panel which there should a be a screw in the door handle, and on the door latch that hold the top and middle of the door on. remove those, and you should be able to lift the door panel up and off the door, where you will see the frame of the door, and a bunch of plastice sealed around the holes of the doorframe. you'll have to cut into the plastic to see the inner workings..... have fun..
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 01-24-2004, 02:57 AM
94tegRS's Avatar
94tegRS 94tegRS is offline
plus the screw in the bottom of the little compartment on the armrest part.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
