Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 01-14-2004, 07:11 PM
bigjoe bigjoe is offline
Angry cold start
Hi folks, I have a 93 villager with 210,000km. Been good to me until now. It has problems with cold starts. It turns over but seems like it floods. Once I get it started it will continue to start no problem unless 5 to 6 hrs goes by, them I am back to square one. Had a tune up done but still the same. Any suggestions?
Old 01-14-2004, 09:45 PM
eltigre eltigre is offline
Re: cold start
check engine codes first but I would look into the engine coolant temp sensor......
Old 01-14-2004, 09:52 PM
Re: cold start
if that checks out then check fuel pressure
Old 01-15-2004, 09:21 PM
Re: Re: cold start
Thanks, but I have done all that. Any other suggestions?
Old 01-16-2004, 12:06 AM
Re: cold start
Then check your BPA (bypass air valve)..
Old 01-23-2004, 06:49 PM
Re: cold start
Ok folks, I figured it out. It was the throttle body. Cleaned it up and she fires up like a champ.
Old 01-25-2004, 09:38 PM
JDW JDW is offline
question on throttle body cleaning
I've got a 94 with 135,000 on it - never cleaned the TB - but it doesn't start as quick as it used to - is that a big job? Will just spraying TB or injector cleaner in the TB do the trick or do you have to take it off and tear it apart to do it?
Old 01-27-2004, 12:08 PM
DPMP DPMP is offline
Re: cold start
I am wondering how the TB get dirty? Was it caused by dirty fuel or air? Anyone tried injector cleaner gas additive? How good do you think that does, as opposed to a full blown injector cleaning service ? I guess this won't clean the TB, right?
Do you have some pictures and procedure of how you clean the TB? My Villager is 166K, probably needs some attention in that area too.
Old 01-30-2004, 10:53 AM
Re: cold start
I had a professional do it. He took the whole thing apart and clean it.
