Old 01-14-2004, 04:53 PM
mike_young mike_young is offline
'93 GrandAm Grinding when breaking
Lately my car has been making a grinding sound when I come to a stop or turn the steering wheel to the far right while driving slowly. There was a higher pitched metal-on-metal grinding sound a few weeks ago, but that seems to have stopped lately. I'm leaning towards break pads, but I've never heard of a grinding sound like this related to break pads. The high-pitched grinding would make me think break pads, but now its more of a lower pitched(but pretty loud) grinding. Any help with this would be great. Thanks.
-Mike
Old 01-14-2004, 05:45 PM
dober-man dober-man is offline
Re: '93 GrandAm Grinding when breaking
Sounds like the high pitched noise was trying to warn you that brake pads were gone. Normally the grinding indicates that you have worn completely through the pads and are now in the process of tearing apart your brake rotors. At this point, your calipers may be suspect also.
Old 01-16-2004, 11:18 AM
I'll change the break pads this weekend and see if that helps. Thanks for the info, I'll let you know how it turns out.
Old 01-16-2004, 11:49 AM
Jpit Jpit is offline
Like dober-man says you may will probably want to replace your rotors also. Quite simple and relatively cheap on our cars to do.
Old 01-31-2004, 04:49 AM
pAint pAint is offline
Send a message via AIM to pAint
Yeah, i kinda ignored the high pitched noise and eventually it turned into the grinding noise. All i did was replace the pads and i got the rotors resurfaced. Recently i just got two new front rotors at pep boys for 20 bucks each. not bad eh
Old 01-31-2004, 11:36 AM
justin0419 justin0419 is offline
Others have already alluded to it, but I'll add something. There are warning sensors located on the brake pads. They generally look like about a 1/2 inch wide hook shaped piece of metal. They'll be facing the front of your car when installed on the calipers. The distance the warning sensor is from the rotor will decrease as the thickness of your brake pads decrease. When the warning sensor first contacts your rotor, you'll likely hear a high pitched squeal. Of course it's best to replace your pads before this happens, but your rotors will still be fine after initial warning sensor contact. If you wait too long after that initial contact, the warning sensor will continue to grind into your rotors and you'll be replacing the rotors too.
Old 02-05-2004, 04:09 PM
I changed the break pads and they work like a charm. The pad on the left was worn all the way down, but the one on the right was only about half. Is this something to worry about? The pad did dig into the rotor a little bit(less than 1mm)but it didn't warp it at all. Thanks everyone for your suggestions.
--Mike
Old 02-05-2004, 10:40 PM
C_Sephiroth's Avatar
C_Sephiroth C_Sephiroth is offline
Send a message via AIM to C_Sephiroth
You shoudl Replace the Calipers and Rotors. Or change the sliders on the calipers, or even make sure they Slide.
Homer: No T.V. No Beer makes Homer go... Something Something or another..............
Marge: Go Crazy......
Homer: Don't mind if I do.....muahahahahahbwauauauauauauau
Old 02-08-2004, 11:23 AM
slacker_53's Avatar
slacker_53 slacker_53 is offline
--Mike
I hope you at least resurfaced your rotors. The rough surface where your worn-down pad ground into your rotor will eat up your new brake pads in no time, could also make your car 'pull' some while braking.
-slacker
When I die, I want to die peacefully in my sleep, just like my grandfather................not yelling and screaming like the other people in his car!
http://www.geocities.com/tbuckit1/index.html
Old 02-09-2004, 01:54 PM
Overtime's Avatar
Overtime Overtime is offline
Send a message via AIM to Overtime
Re: Re: '93 GrandAm Grinding when breaking
Which may be the reason you had one pad worn half way and one worn out.
Old 02-12-2004, 01:53 PM
How would I go about resurfacing my rotors? Would it be less expensive just to buy new rotors? I don't really plan on putting any money into my car unless I absolutely have to, so that is why I ask.
Old 02-16-2004, 08:12 PM
Igovert500's Avatar
blue + red light magnet
if you just need your rotors tuned/resurfaced, just take them to pepboys or any mechanic that does brakes and they should do it for about 7 bucks a rotor.
