Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 01-14-2004, 04:51 PM
2000sierra4wd 2000sierra4wd is offline
Send a message via MSN to 2000sierra4wd
Angry 2000 Sierra ABS problems
I have a 2000 sierra and my ABS light just came on. Is this covered because i heard there was a huge recall for defective ABS pumps. Is there anyway i could fix it or what. I have 22,000 mi on it and already it has had washer fluid pump gone out and the 4wd switch. Hopefully this problem doesn't cost much or anything, i still owe $11,000 on it yet.
Thanks
Old 01-14-2004, 05:57 PM
knocker69er knocker69er is offline
Abs
Well like my post states my ABS light came on too and I have only 10,500 miles on my 2000 sierra. When I first brought it into the dealer they told me that alot of ABS wheel sensors were going out on the 2000's. They said if it was that they would replace them under my extended warranty. Sorry I can't be much help.
Old 01-28-2004, 08:48 PM
99gmcsierra 99gmcsierra is offline
I have a 1999 Sierra PU that has a similar problem. Today the ABS light came on and the sound of a motor could be heard running under the truck. I turned off the ignition and the motor kept running. Called my dealer and the mechanic told me it was a stripped gear in the ABS motor. He said it has not been the first he has seen and he is a small dealer. He disconnected a wire so the motor would not run down my battery. Now I have regular brakes and the ABS and brake light are on constantly. He told me a new part was around $899???!!! The truck has only 45,000 miles on it. No extended warranty but it seems like this has been a recurring problem on Sierra's. Is there any recall or chance that I could get GMC to pay for the repair? Thanks for anyone that can shed some light on this.
Old 02-10-2004, 08:02 AM
jrot013 jrot013 is offline
Angry
I too have a 99 Sierra and the ABS and brake light have come on in the last week. It has 60000 miles and the brakes seem to work fine.
The Question I have is the truck was in a bad accident last June and it cost them $17,000 to fix, and they replaced the frame and was wondering if I could get insurance to fix it because I have a life time warranty on the work that was done and they did remove all the brake equipment and install it on the new frame. Does anyone have any suggestions on what I should do...tips, pointers, anything to go to the delaer that fixed it with?
Come on guys I'm looking for input!!!!
Old 02-13-2004, 03:20 PM
sully16 sully16 is offline
ABS problems
I had the same thing with my 99 Sierra 4x4 ext. cab Z71. two days after I bought the truck used with 80k on it the abs pump started to run full time until I pulled the big abs fuse in the under hood electrical center. After much research and phoning around I found out that these trucks quite often have the abs module malfunction. What I did is go on ebay and found a used abs pump with module that was tested and had warranty and changed it myself in about 1 hr. Boom, all was fixed, the abs light went off and the pump stopped running. That was 2 years ago now and all is still well. The abs has been tested many times and works perfectly. I still check ebay every once and a while for this parts and there are always lots on there for about $100US. Hope this helps.
Old 02-14-2004, 08:09 PM
Question
Thanks sully, is this what I'm looking for....?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2459680866
or do I need just the controller box?
99 Sierra
Midnight Blue
Smashed in June
Fixed in Sept.
Bought for $15000
Fixed it for $18000
You figure it out!
Old 02-15-2004, 08:31 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: 2000 Sierra ABS problems
Contact Galvin Curtis at Circuit solutions...He is repairing the ABS module for about $100
www.circuitsolutions.info
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
