Old 01-14-2004, 04:30 PM
diamondxt diamondxt is offline
Coolant leak
I have a 2000 Suburban with a coolant leak. The only place we can find wet is a wire harness under the starter. It is dry everywhere else. The check coolant light comes on about 1000 miles. It is a leak, not using or going into the engine. Any help would be appreciated.
Old 02-29-2004, 10:48 AM
Rileydn Rileydn is offline
Coolant Leak
Take a mirror and bright lite and check the back right corner of the intake manifold. The Vortec engine uses a plastic molded manifold gasket and they are infamous for leaking. The coolant will run down the back of the head and onto the starter. I had a similar problem and thought it was a freeze plug behind the trans bellhousing. Further investigation revealed it was the intake manifold. About $60 bucks for gasket and anti-freeze and 4-6 hours work or around $450 at the garage.
Old 03-18-2004, 07:56 AM
bluephi1914 bluephi1914 is offline
Send a message via AIM to bluephi1914 Send a message via Yahoo to bluephi1914
Re: Coolant leak
Sounds like it might be the intake manifold. the dealer told me that Suburbans are notorious for leaking there after about 85k miles. i had to replace my intake gasket... was leaking and i couldnt find out where,
Turns out it was the intake... unfortunately this is a common problem. better fix it before it starts leaking into the block
Old 04-13-2004, 11:30 AM
Ketch Ketch is offline
Re: Re: Coolant leak
Did the poster ever get this fixed? What was your result?
Rileydn wrote "About $60 bucks for gasket and anti-freeze and 4-6 hours work or around $450 at the garage."
I had this problem on my 1999 5.7liter sub 2wd.
Did it myself but took me a couple of days. Lots of stuff to pull off and you gotta get that manifold surface very clean. YOu also gotta get the torque right and even on the manifold bolts.
But still worth DIY. I had two quotes of $500 and $600 from local indie shops.
The best thread on this was over in the Tahoe forum. It would be good if the admin would combine the two forums (for obvious reasons.)
Old 05-09-2004, 11:35 PM
Regency Burb Regency Burb is offline
Re: Coolant leak
I recently got out of this with a retorque. A friend had suggested to try it first. He got an extra 40k out of his. My bolts were all loose, and the leaks are gone. I had one in the front and one in the back. We'll see how long it will last, but it's been a little over a month so far.
Old 05-10-2004, 07:26 AM
Re: Coolant leak
i had the same problem w/ my 99sub. but i thought they fixed this problem in 2000
'94 3800TS: power steering and coolant leaks jarl Trans Sport 1 08-03-2010 04:02 PM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 07:53 AM
2001 Chevy Cavalier Coolant System Problem getwilde Cavalier Problem Diagnosis 0 09-18-2009 06:43 PM
2000 Blazer lower intake plenum coolant leak Sedatedbylife Problem Diagnosis 8 06-27-2009 10:20 PM
98 Grand Caravan 3.3L Coolant Leak hooperkj Caravan | Voyager 4 04-22-2009 04:17 PM
