Old 01-14-2004, 04:18 PM
sleepman54 sleepman54 is offline
99 keyless remote for intrigue
need help programming a keyless remote for my 99 intrigue.
Please help!
Old 03-31-2004, 03:45 PM
Dr_Z Dr_Z is offline
I know this thread has not been replied to in the last 2 months, but here is your answer to your question and anyone that is looking for the same info:
With doors closed:
1) Insert Key in ignition and turn to the run position.(do not start the car)
2) Turn key off and take it out of the ignition.
3) with the Driver side door lock switch, hold it in the Unlock position.
4) While holding the Drivers side door lock in the Unlock position, insert Key in ignition, without tunning it on, 3 times. On the third time, leave the key in the ignition.
5) Release the Drivers side door lock switch. You should here three door dings. If you do, this will indicate it is in the Keyless remote programing mode.
6) With your Remote, hold both the Lock and Unlock buttons at the same time untill you hear "two" door dings. This will indicate the remote is programed. (this can take upto 15 seconds) You can program up to 4 remotes while in this mode.
7) To stop keyless remote programing, Take key out of the ignition.
Hope this can help people out...
BTW, these instructions will work for the 98-99 Buick Centurys also.
Dr_Z
Old 07-02-2004, 09:54 AM
timbo40reale timbo40reale is offline
this advice worked for our intrique, thanks for your help
Old 03-01-2006, 07:11 AM
stevewidz stevewidz is offline
Re: 99 keyless remote for intrigue
I followed these steps, but in step 6, instead of hearing 2 door dings, the horn chirped 3 times. What does this mean?
Also, the remote still does not work.
Program 2007 camry keyless remote marty.graw Camry/Camry Hybrid/Vista 1 03-31-2010 08:13 AM
FS 2001 Acura CL Keyless/FOB Remote TMO Classifieds 1 05-24-2009 05:15 PM
remote keyless entry problem smity9089 Intrigue 0 04-13-2009 11:45 PM
chime indicating keyless remote error - 2003 Pontiac Grand Am Jcolli06 Grand AM 1 02-18-2009 06:37 PM
I have keyless entry, but no keyless remote for my 96 Tahoe - need advice Adventurer_96 Tahoe 3 01-25-2008 01:07 AM
