Old 01-14-2004, 03:26 PM
dober-man dober-man is offline
Battery / charging problem
1993 GA 4 cyl. Replaced starter and all appeared fine. Daughter drove the vehicle to school the next day, but it was dead when she tried to leave to come home. Turn key and get no dash lights, buzzers or anything. Could the reman starter be the culprit? If so, how do I check? Leaving work early right now to see if it will take a jump and maybe get it back home.
Old 01-20-2004, 12:03 AM
Green Hornet Green Hornet is offline
Re: Battery / charging problem
Sounds like alternator to me. But most auto parts stores will test your starter and/or altrenator and/or battery for free
Old 01-20-2004, 06:10 PM
gserve gserve is offline
Check the connections on the starter and battery that you disconnected
to put the new starter in. clean battery terminals and check voltage of battery should be 12V off and 13 to 15v running. Check ground connections and battery cables.
battery charging problems??? HELP Twyztidmind '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 01-16-2006 08:51 AM
95 Buick LeSabre battery charging problems tomtrout LeSabre 3 09-06-2005 09:29 AM
alternator/battery/charging problems richm32817 Sportage 0 09-05-2005 04:40 PM
battery charge problem smallride Fiero 4 10-01-2004 07:25 AM
battery charge problem smallride Fiero 1 07-03-2003 01:13 AM
