Old 01-14-2004, 12:08 PM
grayspot1 grayspot1 is offline
1997 venture keyless entry
just bought van. how do you reprogram remote?three button
thanks mike
Old 11-23-2005, 11:36 AM
mark0978 mark0978 is offline
Send a message via ICQ to mark0978 Send a message via AIM to mark0978 Send a message via MSN to mark0978 Send a message via Yahoo to mark0978
Re: 1997 venture keyless entry
thanks mike
Did you ever find out how to program the remote?
Old 11-25-2005, 07:45 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Important! Once the BCM enters program mode, all transmitters must be programmed at the same time. Any transmitters not learned at this time will be erased.
1) Remove the key from the ignition cylinder
2) Remove the BCM PRGRM fuse from the fuse panel
3) Close all the doors
4) Close the liftgate
5) Turn the ign lock cylinder to the ACC. position
6) Turn the ignition lock cylinder to OFF, and then back to ACC within 1 second
7) Open and close front passenger door
A chime will be heard when the system enters the BCM programming mode
IMPORTANT!
After 7 seconds a chime may be heard confirming successful synchronization. It is necessary to wait approximately 14 seconds for a second chime that will confirm successful programming.
8) Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds
9) Repeat the previous step on each additional transmitter to be programmed.
10) Remove the ignition key from the ignition cylinder
11) Install the BCM PRGRM fuse back into the fuse panel.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 12-18-2006, 05:00 AM
scgraham scgraham is offline
If you have the owners manual it is in it
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 05:46 AM
remote keyless entry problem smity9089 Intrigue 0 04-14-2009 12:45 AM
1997 venture Keyless entry not working scgraham Venture 0 12-18-2006 04:52 AM
HELP NEEDED 1997 venture keyless entry program instructions gambler Venture 1 04-09-2005 09:56 AM
99 Chevy Venture keyless entry remote seekin Venture 2 12-10-2004 09:31 PM
