Old 01-14-2004, 12:16 AM
PrivateMalone PrivateMalone is offline
Axle ratios for the V8
i have a '66 and it has been changed to a V8 from a straight 6. What is the axle ratio for the V8. would the axle ration be something i need to change, since the new engine has more power to it?
Old 01-14-2004, 07:22 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Run the stang till it needs a new rear.
Its been a while since I was into the older model Stangs, but the 6cyl Stangs had pretty good rears in them.
It really comes down to if you want an open or a limited slip rear. I would go Limited Slip if I had a V8.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Cars for the Cure 2009 Pictures Pastapuck Car Shows 0 02-11-2009 10:45 PM
Stock Compression Ratio for the '02 4.0L? Kuhn Wrangler 1 08-19-2007 06:34 AM
Compression ratio for the toda A,B,C & D tegdc2r Integra 1 06-20-2003 12:57 AM
Compression ratio for the toda A,B,C & D tegdc2r Integra 0 06-19-2003 09:22 PM
What are the gear ratios for the 94-97 DarknessRS Accord/TSX/Accord Hybrid 0 01-19-2002 03:29 PM
