Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 01-14-2004, 12:23 AM
soloithz soloithz is offline
Send a message via AIM to soloithz Send a message via MSN to soloithz Send a message via Yahoo to soloithz
code 43 on a gmc jimmy
I have a 1994 gmc jimmy thats has a problem, The engine code (self diagnoses) came up with a 43 code and by the def. is what it the prob is. "Knock sensor signal was either above 3.5 volts or below 1.5 volts for at least 20 seconds" what exactly does that mean the sensor is bad or something else is causing it to be bad. The engine idles rough and at times its hard to start (constent cranking) then starts. sometimes when starting up it puffs out black smoke (i know that mean that its running rich) and at other times it has a foul odor (i believe to be the cat. working) it purges but the motor never dies do you think any of you guys could help me out. my email address is [email protected] if you could help i would really apreate it. thank keith horn
1996 GMC jimmy surging 600cuin Jimmy 1 10-05-2010 07:37 PM
96 GMC Jimmy Help....O2 Sensor?? corhey88 Jimmy 1 02-15-2010 07:24 PM
96 GMC Jimmy black smoke, backfires, Timing? corhey88 Jimmy 38 01-31-2010 04:29 PM
Blowing ECMb fuse 1990 gmc jimmy 350 bmxer20n Problem Diagnosis 1 07-10-2009 06:47 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 07:44 PM
