Old 01-13-2004, 07:55 PM
90HF_Project 90HF_Project is offline
Question Field SFC Hyper R - Install Help
Looking for some help with installing the Field SFC Hyper R in a 90' HF with a PM6 ECU. I had the unit wired in to the car and the car ran fine with the Main Power ON and the SFC OFF(MODE light GREEN and UP /DOWN Arrows GREEN). As soon as I turned the SFC ON the engine would bog down and the check engine light would come on. The ECU LED was blinking error code 3, a MAP sensor problem.
I confirmed the ECU terminal location(C14) of the MAP wire. I was able to get the RPMs and the Speed to display correctly with the MAP leads from the SFC disconnected. I reconnected the MAP leads from the SFC and the error condition returned. I used another MAP sensor to make sure that was not the problem.
If anyone knows anything about this, or any links to get help I would really appreciate it.
Field Sfc-Vtec COntroller HELP Marco_B20Vtec JDM Motor & Parts info/chat 5 01-10-2008 12:57 AM
Field SFC Hyper R - Install Help 90HF_Project Let's get Technical! 1 12-17-2004 12:56 AM
Review: d16z6 w/ Field SFC-VTEC 91civicDXdude '88 - '91 Civic | CRX | Wagon | Shuttlee 18 01-03-2004 12:40 PM
Field Sfc bastantena General Discussion 0 12-17-2002 08:56 AM
Field Sfc-vtec Controler bambam2000 Prelude 1 12-13-2002 02:17 PM
