Old 01-13-2004, 07:53 PM
huntarts huntarts is offline
Question Bulb Replacement
Anyone got any idea how to get in to replace the bulbs at the front of the car? I am not even sure if they do anything if they are blinkers or what. But I got bulbs for them but cant find a way in. No scews on the front and from the underside it looks like they are blocked off by panels. The only way to get in looks like from the wheelwell.......but that cant be right to change a bulb........there are like 30 bolts to take out there. Any help?
Thanks in advance!!
Jason
Old 01-13-2004, 10:43 PM
blkcavi02's Avatar
blkcavi02 blkcavi02 is offline
Send a message via AIM to blkcavi02
Re: Bulb Replacement
you have to take out the headlights there should be four bolts and they should pop right out and then just disconnect the bulbs and put the new ones in
Old 01-15-2004, 08:10 PM
03'cavalier 03'cavalier is offline
what year cavy do you have. I know on the 03-04's there is a plastic flange above the headlamp assembly, theres 6 little black clips that hold it in place. your car might be similar so try that, thats how i replaced my headlights.
Old 01-17-2004, 02:43 PM
Numus Numus is offline
Lol front headlights are fine.. the diagram in the owners manual is great at that.. NOW TRY TO REPLACE THE BACK LEFT BLINKER!!!!
The right one is easy just turn the assembly and it pops out the bulb but the left one.. they don't tell you in the manual but you have to unbolt the whole assemble to remove the light because just turning it and the bulbs plug gets jammed in the metal bracket.... the bracket on the left side is smaller then on the right side...
Old 01-19-2004, 11:48 PM
left blinker?
tail lights are easy, go in through the trunk, remove the 3 small bolts and the whole lens assembly comes out, then just pop off the harness and plug in your new bulb and your done.
Heater knob bulb replacement - 93 geschaef Camry/Camry Hybrid/Vista 2 02-16-2010 02:54 PM
2001 License Plate Bulbs Delawn Interior | Exterior | Appearance 5 07-31-2009 11:29 PM
headlight bulb replacement ??????? drewes Altima 15 12-01-2006 12:49 AM
Front bulb replacement yMercedes Altima 5 03-11-2005 04:28 PM
Front turn signals bulb replacment brach Jimmy 1 04-13-2003 10:49 PM
