Go Back   Automotive Forums Car Chat > Buick > Regal
Old 01-13-2004, 03:26 PM
jimmyf jimmyf is offline
Error Code 41
My Serivce ENGINE light has stayed on the last 3-4 months. I only drive the car to work. (20 miles roundtrip) It is a code 41 (cam Sensor). How do I troubleshoot this problem? Should I be concerned? Thanks.
Old 01-13-2004, 08:20 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
What year regal? What engine??
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 01-13-2004, 08:35 PM
pcv pcv is offline
The vehicle computor is telling you that there is a problem with your cam sensor. I'd replace it otherwise the vehicle will one day refuse to start when you want it to.
Good Luck.
NOTHING LIKE AN OLD CAR.
Old 01-14-2004, 05:50 AM
It is a 1991 Regal. The engine is a 3.8L
Old 01-14-2004, 05:52 AM
Is the Cam sensor difficult to replace?
Old 01-15-2004, 08:33 AM
RABarrett RABarrett is offline
Re: Error Code 41
Though the cam sensor is the likely cause, simply replacing the unit is not a good idea. Without troubleshooting the problem, you might miss the fact that the signal goes from the sensor to the ignition module and than to the ECM. Without tracing the problem, this oversight could prove expensive. The cam sensor is used by the ignition module to time spark delivery and by the ECM to sync the injection. Without it, the engine will run, though poorly, but will not restart on shutdown. In general, it is not a good idea to ignore warning lights. Ray
Old 01-19-2004, 11:36 AM
gumby28g gumby28g is offline
Re: Error Code 41
Camshaft Sensor
REMOVAL AND INSTALLATION
Disconnect battery ground cable.
Remove water pump pulley attaching bolts, then the serpentine belt and water pump pulley.
Disconnect sensor wiring connector and remove sensor retaining bolt.
Twist and pull sensor to remove.
Reverse procedure to install and prior to installing new sensor, lubricate sensor O-ring.
01 Town & Country error code explanation jehanny Caravan | Voyager 3 10-14-2009 12:34 AM
2002 QX4:Error Code P1320 Michael.Jones Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 07-20-2009 11:09 AM
error code 300 no other codes brokeneckdave Blazer 6 02-07-2005 05:20 PM
Stalling, Bad Error Codes, Strange Error Lights mrwjr2003 Regal 0 05-21-2004 09:34 AM
Engine error code Pancor Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 03-12-2001 10:31 PM
