Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 12-24-2001, 06:40 AM
300kw ford falcon 300kw ford falcon is offline
Exclamation Nitrus Oxide Intercooling For Supercharger
Im getten the nos to act as an itercooler 4 my supercharger how much more kw do u think it will give it when i hit th emagic butten?
Old 12-24-2001, 09:09 AM
AlexB AlexB is offline
Send a message via AIM to AlexB
Depends how large of a shot of N2O you inject. If you inject about 100 shot, you should get 110-120hp probably because it compliments the supercharger. You should get an intercooler too for even more effect! hehe
Old 12-24-2001, 09:10 AM
By the way, I'm in Melbourne too! Melbourne Florida!
Old 12-24-2001, 02:58 PM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
are you spraying nitrous into the intake as an intercooler? or onto an intercooler... you can do both, it's effective either way...
the cooling effect of the nitrous is similar to using a water injection system, but with the nos you get the added bonus of the extra power...
the nitrous will chill the incoming air, as well as increase the compression in the cyl as there is more o2 in there... so it will add boost as well as power... the thing to note though, is that nos makes the exh gas reallllllly hot, and anything over 1100 degrees f will melt pistons, and with that much power w/nos and s/c, you can do it quick...
so do it right and it'll work...
what kinda s/c and which motor is in that car? is it a 5.0?
Old 12-24-2001, 06:36 PM
it is an australian made power flow centrifical supercharger (6psi) u can find it at www.sta.net.au
Old 02-10-2002, 07:38 PM
mewhoyou mewhoyou is offline
How To N2O
I am a newbie in the world of N2o. I am runnng a mitsubishi 4g93 engine and I need to know, what or how do I install N2O the proper way???? Is there a webpage that tells me what I need to buy and how to install it??
Old 02-10-2002, 09:21 PM
LjasonL's Avatar
LjasonL LjasonL is offline
Some Guy
Send a message via AIM to LjasonL
Re: How To N2O
if u have a "dry" kit basically u drill a hole into your intake just before the throttle body and mount the nozzle there. mount your bottle, run the lines, mount the solonoid, then mount your arming swith and activation swith. a lot of modern kits have a throttle pressure activation switch instead of a button u can push though. in which case u will need to hook into a vacuum pressure sensitive fuel regulator (if u have one, most modern cars do) the kit should come with install instructions that will guide u through, "dry" kits are pretty simple.
Old 02-10-2002, 11:30 PM
fastrThanU fastrThanU is offline
wouldn't you want to take your intake manifold off? if you drill with it still installed, i would imagine that you would run a pretty good chance of getting metal chips and slivers into the cylinders.
11.67@117
"plaster your ass to the back glass"
.... put yer motor where yer mouth is.....
Old 02-10-2002, 11:43 PM
LjasonL's Avatar
Some Guy
yeah if u were drilling it into your manifold u would, but i was referring to the kits that put the nozzle in the intake tube after the air filter but before the throttle body. itd probably still be a good idea to take it off though. good point.
