Old 01-13-2004, 01:30 PM
houtendvan houtendvan is offline
Crazy doorlock
Hi all,
As you mebey know I have a Dodge Ram Van (Dodge Caravan in the US) from 1998. Sinds I got the car I have some problems with the central doorlocking.
Normaly it has to work like this: Put key in, turn to open, hold for a couple of seconds and all locks has to open.
Now what is my problem ?
Put key in, turn to open, try to hold for a couple of seconds but the mechanism wants to turn to the lock side. Sometimes the lock looks like it's unlocked but when I turn the key back to get it out, all doors will lock again....
Sometimes it takes me 3 times to open the door.... This only happens on the driverside door. When I put the key in the passengerside it will sometimes push back but the doors will open in 1 try.
Who knows the answer ?
Dennis
Old 01-13-2004, 08:52 PM
gforster gforster is offline
Re: Crazy doorlock
Dennis,
This is an easy fix... remove the door panel and carefully unclip the white plastic switch on the back of the lock mechanism. there are two wires going to it. Now you need to carefully take it apart and clean the old grease out of it and clean the contacts inside really well. Reassemble and test. Should now be working A ok. I had this problem with mine, exactly as you stated. Or you can just purchase a new lock switch. Good Luck,
Geoff
Old 01-14-2004, 03:34 AM
Geoff,
Thank you very much. I will try your solution.
Tnanx again,
Dennis
Old 01-14-2004, 05:13 PM
Yes !!
I did what Geoff told me to do and I fixed the lock this way !
Geoff, again,
THANKS
Old 01-14-2004, 10:01 PM
Re: Crazy doorlock
Dennis,
Glad I could help you!!! Good to hear.
Geoff
Crazy Acccident fjmustak Car Videos 2 11-23-2010 02:02 PM
Find out Doorlock code? Perfectday Explorer | Explorer Sport Trac 4 10-27-2003 10:52 PM
No Horn, No Doorlocks NGillman Corsica 7 10-23-2003 08:47 PM
Automatic doorlocks Crashed '88 - '91 Civic | CRX | Wagon | Shuttlee 11 06-25-2003 01:50 PM
