Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 01-13-2004, 08:29 AM
Surrexi Surrexi is offline
'Most' Easy to install....?
I was wondering which is easier, a turbo or a super? I realise a super is belt driven to there are more mods to be made. However on a car that DOES NOT HAVE STOCK turbo or supern (I.E. my 4.6l V8 Tbird LX), what is recommended for ease of installation?
(Common sense tells me a tubo, but thought I'd check ne ways)
EDIT: Turbos also seem to be cheaper, is there a reason?
Old 01-13-2004, 10:10 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Actually, I would say a super-charger is easier to install.
Old 01-13-2004, 10:21 AM
2turboimports's Avatar
2turboimports 2turboimports is offline
Re: 'Most' Easy to install....?
mmmm....i would have to agree. on a v8 supercharger would be way easier to install.
i dont know where your shopping for your turbo parts, but it's usually a bit more expensive than supercharging. especially with a v8, you'll be looking at a really large turbo, or possibly 2 large turbos..custom piping, intercooler/s, engine management, custom turbo manifold/s, blow off valves, custom downpipes, exhausts, all the headaches of first tuning for boost on a NA motor, oil and water lines to and from the turbo. there's alotta small stuff to consider, it's not just put a turbo here and go.
The same could be said about SC in a way, but it will be very much easier to replace the intake manifold with one unit that's designed specifically for your car.
Old 01-13-2004, 01:32 PM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
for centrifugal superchargers, Vortech units need only be bolted up, a new belt installed, oil lines run to the charger, and the intake (not manifol) redone.
the kit comes with everything you need, including new engine control unit and fuel injectors.
all for 3-4k depending on model and if you buy the intercooler.
Mustangs are nice, but I'd rather have one of these...
