Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-13-2004, 09:25 AM
tsugsr tsugsr is offline
switches
Ok, if your to lazy to read my sig, i just got a 95 GSR teg, well the other day when i was messen around under the dash looking for my alarm controll box, i found two on/off simple metal switches, i kinda thought they may be kill switches but i turned them off and the car started fine. they are on that little panel right next to the clutch pedal close to the floor, right next to that foot rest thing. I have no idea what they are, i havnt really had to much time to mess with them, not to mention its really freakin cramped down there, so does anyone have any idea what they could be? thanks
Old 01-13-2004, 02:41 PM
Spectre927's Avatar
Spectre927 Spectre927 is offline
Send a message via AIM to Spectre927
Re: switches
Is that how kill switches work? I dont think I have one. Off the top of my head, I can't see any reason for those, but I'll mess around with mine, to see if i even have any.
Old 01-13-2004, 04:05 PM
JDMDB7 JDMDB7 is offline
Re: switches
They're not stock switches.
If it's a kill switch you'll have to let the car run for 30 seconds or so before it will use up the available fuel and shut down. But that's a bad location for a fuel kill, so I doubt that's what they are.
Do you have an aftermarket alarm? It could be a valet switch.
If it's neither of those they could be dead left-over switches from something the previous owner installed, like neons or something. You can easily take the panel off and see where the wires go (if there are any wires).
Old 01-13-2004, 04:15 PM
Re: switches
isnt it bad to use up the extra fuel? i dont want to mess it up. and i have an aftermarket alarm, how would i test to see if they are valet switch? and we tried following the wires, but we couldnt tell where they led. thanks for yalls help.
Old 01-13-2004, 04:46 PM
Re: switches
No. If you're really worried about it you can just turn the key to "on" without starting it for 10 seconds the next time you start it.
If it's a valet switch you should see a confirmation signal from the alarm light/led. Assuming it's a keyless entry alarm system... With valet switch off it will lock the doors and arm the system. With the valet switch on it will lock the doors but not arm the system. It would be much more handy if you had the manual for the alarm, but I doubt that's possible.
Old 01-13-2004, 06:42 PM
Re: switches
well i ran it for more than 30 seconds and it never shut off, so im guessing its not a kill switch, and i dont have the manual for the alarm, this is gonna bother me till i figure it out lol.
Old 01-13-2004, 06:59 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: switches
You may just have to trace the wires.
Old 01-13-2004, 09:00 PM
Re: switches
i guess so, one day when im bored ill get out there and do that, thanks for yalls relpies guys.
Old 01-14-2004, 12:11 AM
Teggy Pwnage Teggy Pwnage is offline
Send a message via AIM to Teggy Pwnage
Test it with a volt meter. Some one may have just cut the wires for a neons or something else and left the rest.
Old 01-14-2004, 12:19 AM
94tegRS's Avatar
94tegRS 94tegRS is offline
Re: switches
yeah, just follow them as far as you can, then go to places youd expect to have them come out and if you see wires that arent stock, do a continuity check and if its the same wire then follow it from where you just discovered it and see if you can find it.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
