Old 01-13-2004, 07:42 AM
corvair corvair is offline
Code Check Connector
Where can i find the check connector to pull codes on a 93 prelude si
thanks
Old 01-13-2004, 09:42 AM
Bambooseven's Avatar
Bambooseven Bambooseven is offline
Re: Code Check Connector
down by the ecu there'll be a jumper with a green cap on it (passenger seat floorboard)
MY CAR!
Old 01-14-2004, 08:04 PM
thank you
Old 01-14-2004, 10:19 PM
fsthonda12 fsthonda12 is offline
Hey i have a ? about Engine codes. I need help on my car the motor says it is a b16a and the # underneath is 1013163. I need to know what engine it is. HELP
Old 01-15-2004, 12:16 PM
well been at it well over 2 hours and i cant find the connector i've got the carpet up and the glovebox/owners manual box out metal cover off ov the ecu and i'll be darned if i can find it. would it be possible to jump it at the ecu?
Old 01-15-2004, 12:43 PM
For Anyone Interested The Ecu/ecm Code Check Connector For Pulling Codes Is Located On The Drivers Side Console Under The Dash.
