Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 01-13-2004, 02:20 AM
Unlawful 240sx Unlawful 240sx is offline
Send a message via AIM to Unlawful 240sx
Traction Control Light---Low Tranny fluid???
Is it possible for a traction control light to come on and cause errors in the system due to excessively low transmission oil. Or does the traction control have nothing to do with the transmission in that way.
Old 01-13-2004, 04:15 PM
Marc_Aurora_2001's Avatar
Marc_Aurora_2001 Marc_Aurora_2001 is offline
The traction control system is tied in with the engine and brakes.
There's no connection to the trans, so low trans oil would not
cause the traction control lights to come on.
_______________
GM!!! SAVE OLDS!!!
Old 01-16-2004, 12:00 AM
dsatt12 dsatt12 is offline
The TCS is pretty much just a controller that sits under the left front fender well and uses wheel speed sensors to run both the traction control and ABS systems. If the light comes on w/o the ABS light coming on as well it is almost certainly a bad wheel speed sensor. The bad news is you have to change the whole wheel bearing assy to swap it out. You can go for a looong time without it and do no harm though.
