Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 01-12-2004, 10:37 PM
dave4444 dave4444 is offline
Question HVAC fan control
Hi,
A few months ago my 98 Malibu HVAC fan control partially broke. Speeds 1 and 2 stopped working, while 3-5 were still functional.
Today 3-4 also stopped leaving just off and '5'. Kinda annoying.
I'm hoping this is a simple fix/replacement that I can do myself but I'm unsure where to look for the problem.
I appreciate any help. Thank you.
Old 01-14-2004, 10:25 PM
scorch462558 scorch462558 is offline
Send a message via AIM to scorch462558
Re: HVAC fan control
Sounds like the resistor, it is common for the Malibu it is on the passenger side behind the blower motor real close the the fire wall.cost about 25 bucks
Old 01-15-2004, 09:39 PM
capricex capricex is offline
question about hvac
my malibu 's air setting are off-like 1, and 2 barely pump out anything while 3,4, 5 work, is the part that u guy talking about have two compintents to it, like the part would be shot is only 1 and 2 opperational ,and the 3-5 adjustings are on a second part?
Old 01-16-2004, 04:03 PM
Yes You just have to replace the resistor. When it goes bad it will take out setting 1 & 2 of the fan, and let 3,4 & 5 run.
Old 07-12-2004, 02:50 PM
charlesw1970 charlesw1970 is offline
Exclamation
Is it in the same place for a '99 Malibu?
There are no stupid Questions,
but there are a lot of inquisitive idiots...
Old 07-13-2004, 07:22 AM
BeatnikTermite BeatnikTermite is offline
Go to http://www.automotiveforums.com/vbul...d.php?t=199000 for the procedure. The procedure is the same for all 1997 to 2003 models, and is very common.
Old 09-13-2004, 06:16 PM
beaker8 beaker8 is offline
Blower still won't fully work with new resistor
Note: this is the second place I've posted this reply, but this thread seems more relevant.
I had blower fan speeds 1,2,3 die on my '00 Malibu (second time it has happened, first time was fixed by a dealer 2 years ago). I decided to try and fix it myself this time and went to Autozone and got the replacement resistor pack part for it ($17). After replacing the part, the blower worked on 1,2,4,5 (NOT 3). Looking inside the 5-pin connector on the part, I saw that pins D and C were connected on the new part, but not on the old part. I figured that Autozone had the wrong part, so I returned it and went to my local Chevy dealer's parts department to get what I thought would be the "genuine" part. Sure enough, when the parts guy pulled the AC Delco labeled part out of the box it was the IDENTICAL part (D-C pins connected, colors, size-new one is bigger, both made in Japan, same 4 little lumps on the back, etc., etc...). I'm 99.9% sure that both the dealer and Autozone had the exact same part, but the Chevy dealer swears up and down he has replaced dozens of these and never had a problem with one blower speed not working. Has anyone else here who has tried replacing the resistor pack had this problem? I would rather not give the dealer $100+ bucks to fix what is inherently a bad design.
