Go Back   Automotive Forums Car Chat > Plymouth > Breeze
Old 01-12-2004, 08:39 PM
Dylanite Dylanite is offline
Wheel Bearing
Lately I have been getting a loud humming from my rear right side. I have had older cars with wheel bearings gone and they sounded the same. I have also replaced wheel bearing on other models easily. I took the wheel/hub off today and instead of a cotter pin removal and popping out the bearing it looked much different, and had a white plastic washer on it that made it look as though it was not to come out. Has anyone replaced one on a 97 Breeze before. Is there much trouble or something I should know? Also I have notice and rubber type of burning smell form the same wheel after driving. Could it be a brake problem and not a bearing? Any help appreciated.
Old 09-21-2005, 05:52 PM
Doc74 Doc74 is offline
Re: Wheel Bearing
I replaced both front hubs(weelbearings on my wifes 96 breeeze, its really not bad at all. i am a mechanic but i know anyone with any ability could do it, just go slow.
Old 09-26-2005, 06:22 AM
chevy00 chevy00 is offline
Re: Re: Wheel Bearing
are these pressed in? quick run down on how to do. thanx
Old 10-27-2005, 07:57 PM
Matts3100 Matts3100 is offline
Send a message via AIM to Matts3100
The wheel bearing is part of the hub assembly wich is bolt on. I have the same problem with my 98 breeze. I was wondering if anyone knew the axle nut torque specs?
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 10:27 AM
2000 Venture "buzzing" wheel bearing ? pjw73nh Venture 9 02-29-2012 07:23 PM
89or90 2600i 4x4 rear wheel bearings B4 roadtrip discretegeek B-Series/Bravo/Bounty/Drifter 0 03-29-2010 08:38 AM
89or90 2600i 4x4 rear wheel bearings B4 roadtrip discretegeek B-Series/Bravo/Bounty/Drifter 0 03-29-2010 08:37 AM
Grinding Wheel, Not the bearings. Kbrickman Cavalier Problem Diagnosis 5 04-18-2009 10:22 PM
