Old 01-12-2004, 05:49 PM
ematrixLS ematrixLS is offline
Cool Light behind gas meter burnt out
The light behind my gas meter burnt out a few days ago so only the rpm meter and half of the speed gauge is lit up at night, does anyone know if you can replace the light ? I found a automotive acura book that says you have to replace the cluster, which means i have to replace all 3 guages and the light comes as part of it ( I assume ) I am wondering if this is true and if it is how I would go about doing it and where to getthe part, I'm not really sure even about the name of the unit. Also, isn't the mileage meter a part of that ? This little light is sounding like a giant headache.
Old 01-12-2004, 06:03 PM
rb25stu rb25stu is offline
gas meter
the illum is a cluster of 3v (uk to me)bulbs its not the end of the world its about £2 /////$3000 oz dollars
Old 01-12-2004, 06:26 PM
Cool
So it is possible to replace the light behind the guage ? Do you have to just take off the front plastice thing and then take out the stuff behind it to get to it ? Or do you have to take apart the whole dashboard ? Should I be able to find a bulb that will fit there at a local store or is it a special order part. Thanks again for all you guys help
Old 01-12-2004, 07:23 PM
Bilson8tor's Avatar
Bilson8tor Bilson8tor is offline
Send a message via AIM to Bilson8tor
Re: Light behind gas meter burnt out
you dont have to take out the whole dash to remove the cluster just check you manual
Old 01-13-2004, 08:49 AM
T!mmy T!mmy is offline
Send a message via AIM to T!mmy Send a message via MSN to T!mmy
Yea I think a bulb haswent outsomewhere because my needles don't glow ATALL I don't know what would be the problem because the gauges light up just not the needles...any thoughts?
The Dr. tells me too much masturbation is unhealthy...So when is "too much" masturbation "too much"???
Check out our car club site which I made http://www.almostperfectcc.com
Originally Posted by 18c5sol94
we go from a stop he pulls a little on me (only cause i can't keep the wheels on the ground)
Old 01-14-2004, 09:35 AM
steve8091's Avatar
steve8091 steve8091 is offline
Send a message via AIM to steve8091
You just need to take out the gauge trim (~2 screws and ~4 clips) and the gauge cluser (~4 screws and a few wire harnesses). If you do a Google search for "Indiglo Gauge Install", the hits will have info on how to remove the gauge cluster.
1998 Honda Civic DX Hatchback
http://members.cardomain.com/steve8091
