Old 01-12-2004, 05:47 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Brakes pads
I was going to change my rear brake pads, when i got one of the bolts off on the caliper, but that was it all of the other ones were torqued on too tight. I have tried everything. The bolts are starting to strip, so i stopped. What should i do? Please Help!!!!!!! Thanks in advance.
For Sale 98 Eclipse GS, 5 spd
Old 01-12-2004, 06:34 PM
89Turbo944's Avatar
89Turbo944 89Turbo944 is offline
Re: Brakes pads
Well it sounds weared that a bolt is striping while it is being extracted. You can try heating up the bolt and then lostning it, or shoot some lube on it. But you may end up braking the blots off or ending up needing to re-tap the hole.
Also make sure you are turning the wrench the right way.
Old 01-12-2004, 08:00 PM
CODE4 CODE4 is offline
Send a message via ICQ to CODE4 Send a message via AIM to CODE4
Re: Brakes pads
I can only assume you mean the head of the bolts are stripping since the threads would not be when attempting to remove them. If the heads are stripping then you might be doing something wrong. Are you using a 12 point socket/box end wrench? If so then do not. Use a 6 point. And make sure it fits tight. Even a little play means you are not using the right size. And when you do finally get them out go to NAPA and order some new Caliper bolts and grease them prior to installation.
______________________________________________
1999 Eclipse RS
ET: 16.1 @86.241 | Speedworld Motorplex, Phoenix, AZ
