Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 01-12-2004, 04:24 PM
thundercat901 thundercat901 is offline
My 96 Cut Supreme takes off slow..help?
It started this morning...it was taking off extremely slow,the motor was shaking and making a rattling noise.I haven't been able to take it anywhere yet....could it be the transmission? what else could it be?
Old 02-02-2004, 10:05 PM
slusmiles slusmiles is offline
Could be a fuel injector gone bad. I had a similar problem and that was the answer.
Old 02-10-2004, 09:07 AM
2Olds 2Olds is offline
Re: My 96 Cut Supreme takes off slow..help?
There is a possibility that it could be sensor that is located right on the transmission (on side prolly). However, I can't recall what it is called...lol....typical. Its possible that the sensor is bad.
Old 02-12-2004, 12:01 PM
97Cutlass 97Cutlass is offline
Re: Re: My 96 Cut Supreme takes off slow..help?
There's a good chance it has something to do with your fuel pump... maybe as simple as a filter... but more likely the pump needs to be replaced.
What you're saying sounds almost identical to what happened to friend with a '96 Supreme... He took it to a mechanic (after it "died") and they replaced the fuel pump. Sure enough, the car is now stronger than ever.
