Old 01-12-2004, 09:59 AM
KyleJ25 KyleJ25 is offline
webdes
1. What is a stage? – the stage is where you draw and import artwork, add text and sound, and add additional features such as navigation buttons or other user-interface components
2. What is the Tools Toolbox? – the tools toolbox contains the tools for creating, placing, and modifying text and graphics
3. What are panels? – the panels assist you in working with actions and with objects on the stage, in the entire document, and on the timeline
4. What is a timeline? – the timeline organizes and controls a document’s content over time
5. What is the property inspector? – the property inspector enables you to specify the properties of a selected object
6. What is a designer? – contains panels for creating and modifying graphics and animations, such as drawing, color, and alignment
7. What is the general panel? – contains design and some development panels
8. What is a developer? – contains panels for writing and debugging ActionScript code
9. When you open flash a welcome dialog box opens up how many panels are there and what are they? – 3; designer, general, and developer
10. What set contains the most commonly used panels and will provide you with all of the tools and information you need to get started using flash? – the designer set of panels
11. If you later find that you need to change the panel set, how can you do this? – point to panel sets on the window menu and then select the desired panel set from the list that appears
12. What does default layout set your screen to do? – this will set your screen to panel sizes that match your monitor resolution if the one you selected does not match
13. If you need to consistently open and use a panel that is not part of your workspace what can you do? – you can add that panel to your workspace
14. The Menu bar contains access to what? – it contains access to all of the tools, panels, and options within flash and contains many of the design element and manipulation functions
15. What does the stage contains? – it contains all of the elements that make up a flash document
16. The contents of the stage reflect on what? – the frame currently in the timeline
17. True or False – The Timeline is a key organizational and navigational tool for your animations. – True
18. Where do you coordinate the timing of the animation and assemble the artwork in separate layers? – the timeline
19. You can select the colors for the strike and fill from what? – color swatches panel
